[Live-demo] Project to be included on OSGeo Live GIS Disc
maplabs at light42.com maplabs at light42.com
Fri Jun 10 21:08:49 EDT 2011
side note:
  even though I do not have the 52North server active that I know of,
I see repeated, periodic attempts from something to connect to a
postgres database called "52nSOSv311"
  I have not filed a bug on it for the LiveDVD, but there it is for
your information
Brian Hamlin
GeoCal
OSGeo California Chapter
(415) 717-4462 cell
On Sat, 11 Jun 2011 06:53:05 +1000, Cameron Shorter  wrote:
Thank you for your application Jan. A Web Security Service will be an
> excellent addition to OSGeo-Live.
> I have a couple of extra questions in line below.
> On 10/06/11 22:31, Jan Drewnak wrote:
> > Dear list, Cameron,
> > I ask you to include our project "52°North Web Security Service" on the
> > OSGeo Live Disc. Please find the details below, based on the questions
> > documented at http://wiki.osgeo.org/wiki/Live_GIS_Disc_Apply.
> > Thanks,
> >    Jan
> > * Please describe your application.
> > ** What is its name?
> > -- 52°North Web Security Service
> > ** What is the home page URL?
> > -- http://52north.org/communities/security/wss/2.2/index.html
> > ** Which OSI approved Open Source Licence is used?
> > -- GNU GPL 2.0
> > ** What does the application do and how does it add value to the
> > GeoSpatial stack of software?
> > -- The application adds a security layer to any kind of geospatial Web
> > applications and services, acting as a proxy, without the need to modify
> > existing services. It provides policy-based authorization and
> > authentication features to restrict access to spatial layers, features,
> > and other resources provided by OGC Web Services.
> Very nice. Would it be possible to lock down a WFS to a specific filter?
> Eg: A user is only able to query features that are within a specific polygon?
> > ** What language is it written in?
> > -- Java
> > ** Which version of the application should be included in the next
> > OSGeo-Live release?
> > -- 2.2.0 (final)
> I understand that 2.2 is currently in beta. Have you had a previous
> stable version?
> Maybe 2.1 or 1.0?
> > * Stability is very important to us on OSGeo-Live and we pay most
> > attention to the following answers. If a new user finds a bug in one
> > application, it will tarnish the reputation of all other OSGeo-Live
> > applications as well.
> > ** Has been rolled out to production in a number of locations? Can you
> > mention some risk adverse organizations who use your application?
> > -- Used in some administrative units in federal states of germany
> Can you please expand on this. Has the application been deployed into
> production or is it just in a R&D prototype?
> I assume that these administrative units of federal states are part
> of government? Would you consider these organisations to be risk
> adverse themselves?
> If departments would be ok to be named, it would be nice if you could
> name one or two of them.
> > ** What is the size of the user community and developer community? You can
> > often answer this by mentioning downloads, or describing a healthy, busy
> > email list?
> > -- About 500 download of latest beta release
> > ** Do you have a bug free, stable release?
> > -- Scheduled for end of June, current state is beta.
> > ** Please discuss the level of testing that your project has gone through.
> > -- Deployed on various Windows and Linux platforms, Tomcat versions,
> > tested with several WMS, WFS, WPS, and SOS.
> > ** How long has the project has had mature code.
> > -- First version established in late 2004
> > * OSGeo-Live is targeted at applications that people can use rather than
> > libraries. Does the application have a user interface (possibly a command
> > line interface) that a user can interact with?
> > -- Web UI to set up protected services; policies and users are managed
> > trough XML config files.
> > * We give preference to OSGeo Incubated Projects, or Projects which are
> > presented at [http://foss4g.org FOSS4G] conferences. If your project is
> > involved in OSGeo Incubation, or has been selected to be presented at
> > FOSS4G, then please mention it.
> > -- presented in 2007 to 2009
> > * With around 50 applications installed on OSGeo-Live, us core packagers
> > do not have the time to liaise with every single project email list for
> > each OSGeo-Live release. So we require a volunteer (or two) to take
> > responsibility for liaising between OSGeo-Live and the project's
> > communities. This volunteer will be responsible for ensuring the install
> > scripts and English documentation are updated by someone for each
> > OSGeo-Live release. Also test that the installed application and
> > Quickstart documentation works as expected on release candidate releases
> > of OSGeo-Live. Who will act as the project's liaison person.
> > -- liaison person is Jan Drewnak (j.drewnak at 52north.org)
> > * OSGeo-Live is Ubuntu Linux based. Our installation preference is:
> > *# Install from UbuntuGIS or DebianGIS
> > *# Install .deb files from a PPA
> > *# Write a custom install script
> > :Can you please discuss how your application will be installed.
> > -- Application is installed by script that copies the applications war
> > file into a tomcat webapp folder
> > * OSGeo-Live is memory and disk constrained. Can the application run in
> > 512 Meg of RAM?
> > -- definitely
> > * How much disk space will be required to install the application and a
> > suitable example application?
> > -- about 35 MB
> > * We aim to reduce disk space by having all applications make use of a
> > common dataset. We encourage applications to make use of the example
> > datasets already installed:
> > http://wiki.osgeo.org/wiki/Live_GIS_Add_Project#Example_Datasets If
> > another dataset would be more appropriate, please discuss here. Is it
> > appropriate, to remove existing demo datasets which may already be
> > included in the standard release.
> > -- datasets not needed; data that comes with application has very small
> > footprint (couple of kB)
> We have a few web services installed on OSGeo-Live already. It would
> be good if your quickstart could make use of one of these.
> For example, I understand the mapserver WMS/WFS doesn't require any
> extra memory from a tomcat instance in order to run. You might want
> to make use of it.
> > * In past releases, we have included Windows and Mac installers for some
> > applications. It is likely we won't have space for these in future
> > releases. However, if there is room, would you be wishing to include
> > Windows and/or Mac installers?
> > -- No
> -- Cameron Shorter
> Geospatial Director
> Tel: +61 (0)2 8570 5050
> Mob: +61 (0)419 142 254
> Think Globally, Fix Locally
> Geospatial Solutions enhanced with Open Standards and Open Source
> http://www.lisasoft.com
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
More information about the Live-demo mailing list
