[Live-demo] 5.0alpha2 build logs
Manuel Grizonnet manuel.grizonnet at gmail.com
Tue Jun 28 10:51:20 EDT 2011
For your information, following your recommendations, I've modified the otb
install script which uses now the stable ppa repository built with the
standard distribution gdal package (1.6.0).
Manuel
2011/6/28 Julien Malik <julien.malik at c-s.fr>
> Hello
> Thanks to all for your answers.
> To avoid disturbing the disc alpha release process, we will change the otb
> install script so that it uses the otb packages built with the standard
> distribution packages (gdal 1.6).
> In the meantime, I'll change our patch to fit Even's changeset, and propose
> it for inclusion in the ubuntugis gdal package.
> If it is accepted, we will be able to switch the OTB package to the
> ubuntugis-enabled one (we have one PPA for each version).
> Regards,
> Julien
> Le 27/06/2011 23:50, Hamish a écrit :
>  Even wrote:
>>> Well, you didn't read my previous email probably.
>> (I hadn't)
>>  It is upstream. See
>>> http://trac.osgeo.org/gdal/**ticket/4101<http://trac.osgeo.org/gdal/ticket/4101>
>>> and
>>> http://trac.osgeo.org/gdal/**changeset/22461<http://trac.osgeo.org/gdal/changeset/22461>
>> ok, so the solution would seem to be to try&  convince Alan to
>> get the patch backported into ubuntugis,&  so fixed (well,
>> sidestepped) for all, not just us.
>> thanks,
>> Hamish
Manuel
URL: http://lists.osgeo.org/pipermail/live-demo/attachments/20110628/8251410f/attachment.html
More information about the Live-demo mailing list
