[Live-demo] New MapProxy package
Cameron Shorter cameron.shorter at gmail.com
Wed May 25 07:41:59 EDT 2011
Thanks Olivier,
Based upon your responses, I'm +1 for including MapProxy in OSGeo-Live.
Could others on this list please vote within the next 48 hours. If there
are no negative responses, I suggest that MapProxy be invited to join
OSGeo-Live.
On 25/05/11 18:32, Oliver Tonnhofer wrote:
> Hi Cameron,
> On 25.05.2011, at 09:58, Cameron Shorter wrote:
>> One thing I missed was the size and activity of the community behind MapProxy. Could you please say a few words about that.
> We have a quite active mailing list http://lists.osgeo.org/pipermail/mapproxy/
> Development is still mostly done by us (Omniscale) except occasional bug fixes or small features.
> As usual with open source, it is hard to tell where it is in production use outside of our own projects.
>> Then on a technical level, I'm interested to understand how MapProxy compares with GeoWebCache and MapTiler, which I think both provide similar functionality.
> MapTile is just a tool to create tiles and not a server that can deliver tiles. So they do not really compare.
> MapProxy and GeoWebCache are more similar. The obvious difference is that GeoWebCache belongs to the Java tribe, while MapProxy belongs to the C tribe (actually its Python, but it uses some C libs).
> They are both tile servers that read data from WMS sources, cache the data on disk and send tiles to clients via TMS or WMTS. But MapProxy has a lot more features that makes it easier to solve more complex use cases. For example:
> With MapProxy you can create cascading WMS service that collects layers from different servers. You can limit the extent of each layer with shapefiles and group layers from different servers into your own layer tree. You can enable caching for each layer/layer group. The caching does not only work for tiled requests but also for arbitrary WMS requests (with support for all resolutions - free zomming). It also supports on-the-fly reprojection of cached or cascaded data. You can configure most options for each layer/cache individually (like resampling method).
> FeatureInfo and Legend requests are still supported. FeatureInfo from different servers can be unified with XSLT.
> The seeding tool (for pre-caching) is also much more powerful. You can define the seed extent with shapefiles and the tool is more efficient in general (multi-threaded, optimized seed strategy).
> Hope thats enough information :)
> Regards,
> Oliver
Cameron Shorter
Geospatial Director
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
More information about the Live-demo mailing list
