[Live-demo] Setting up list of to-dos for GeoMoose install on LiveDVD
Bob Basques Bob.Basques at ci.stpaul.mn.us
Thu May 26 17:27:39 EDT 2011
Cameron (and others),
I'm pretty sure I'm going to use the Natural Earth data no matter what, since it will be perfect for seeing the different packages side by side.  But the GeoMoose demos emphasize a Local Municipality use process that I don't believe the Natural Earth dataset can fill in for entirely.   The Web Mercator demo is emphasizing the ability to pull in layers from many potentially different data sources, while not as easy to argue away, it's been a mainstay of the GeoMoose demos for a long time.
Personally I believe there needs to be a set of data for various levels of resolution as a global set, and I don't see the GE datasets filling this need entirely (yet), Maybe the GeoMoose datasets can be used in some of this capacity.  The reason I thought of putting them into their own containers (folders) was to provide a flexibility for others to use if they so desired.  They can also be easily removed in the future.  I'm also planning on building separate Viewers for each, but I can also build a composite viewer.  Each of these using a single frontend jump page (index.html) to get to.
In the end, I (or the reviewers) can pull any of these "extras" out after the fact if the review of these "extras" fails to impress.  :c)
I thought of another question to ask the group as well.  Are there any plans to include more than one browser, or even more than one version of a particular browser?  I've been wondering about Firefox 4 and Chrome for example, because of the WebGL and HTML5 things that can be demonstrated in them.
bobb
>>> Cameron Shorter <cameron.shorter at gmail.com> wrote:
Bob,
I think answers to most of your questions are here:
http://wiki.osgeo.org/wiki/Live_GIS_Add_Project#Directory_Structure
Let us know if not, and we should find out and update our wiki.
Basically, we are following Ubuntu packaging conventions.
A few extra comments below. Hamish may correct me on some packaging comments.
Alan, Alex may be able to help on mapserver questions.
On 26/05/11 08:26, Bob Basques wrote:
All,
So, did some more snooping on the DVD (my USB version), seems the structure of things are a little loose as to where things are planted, so, would these be the correct locations to use is there a preference of any sort:
/usr/lib/cgi-bin/mapserv  (for mapserver.cgi calling  [http://localhost/cgi-bin/mapserv] ? )
/usr/lib/cgi-bin/PHP(5)  (for PHP stuff, - if I get to it . . .)
/usr/local/share/data/natural_earth/  (LiveDVD community data for demos, I also see them in POSTGIS under the "public" schema)
    (Question: are there community Mapserver Mapfiles for the POSTGIS layers or do I need to roll my own?)
Alan, Alex?
And, for adding of GeoMoose stuff . . .
/usr/lib/cgi-bin/<geomoose_custom service(s)>  (GeoMoose specific services)
It seems so.
/usr/local/share/data/geomoose_demo_county/  (Geomoose County demo data)
please use /usr/local/share/data/geomoose/demo_county if you are providing a geomoose example.
However, it is my strong preference that you only use the natural earth dataset for examples. We are trying to move all demos over to the natural earth.
If you have a specific example that can't be shown with natural earth, then please speak up.
/usr/local/share/data/geomoose_demo_mercator/ (GeoMoose Mercator demo data)
ditto
/var/www/geomoose/  (Geomoose install)
yes
Apache Config stuff should go???
/etc/apache2/conf.d/geomoose (pointer to geomoose apache config)
It seems so
I think that's everything.  Did I miss something?
bobb
>>> Hamish <hamish_b at yahoo.com> ( mailto:hamish_b at yahoo.com ) wrote:
Alex wrote:
> Also make sure to use the "mini" image to make a usb stick
> there is a known bug in the full iso that may cause it not
> boot which we haven't had a chance to fix yet.
just to note two other bugs in the 4.5 release just found and
fixed in svn (both trunk & the 4.5 release branch):
Problem: gpsdrive Mapnik/OpenStreetMap rendering broken
Reason: renaming of Natural Earth layers late in the rc cycle. oops
Solution: edit ~/.gpsdrive/osm.xml and change "10m-urban-area"
to "10m_urban_areas".
Problem: welcome message never appears
Reason: i18n efforts trod on copying the script to where it
needed to be. oops
Solution: copy ~/gisvm/desktop-conf/welcome_message.sh into
/usr/local/share/osgeo-desktop/
I expect those two, plus the Windows installer filename problem
can be hand edits to the primary VM image, and a new full-build
would not be not necessary. (I hope)
Hamish
ps- zygrib now has a quickstart, so we are 100% for those now.
(copy editing requested)
(do check out the CAPE instability [tornado/tstorm predictor] for
the S.E.rn USA currently.. some 1000s of J/kg .. ouch)
Live-demo mailing list
Live-demo at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/live-demo
http://wiki.osgeo.org/wiki/Live_GIS_Disc
Cameron Shorter
Geospatial Director
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
URL: http://lists.osgeo.org/pipermail/live-demo/attachments/20110526/f1727c14/attachment-0001.html
More information about the Live-demo mailing list
