[Live-demo] Release Checklist 5
Alex Mandel tech_dev at wildintellect.com
Tue Sep 6 22:19:30 EDT 2011
Switch is flipped, added a README.txt to the webextra directory
explaining how to do it for future releases - it's just a symlink
replacement, no need to touch apache. If you want a new image up, and
it's all fixed in svn let me know, but I'm not going to worry about it
until after Foss4g (real minor issue).
3 US mirrors (2 at UCD) and 1/3 a Greek mirror are up (small typo in the
mini needs to be fixed). Not sure if we'll have a German mirror this
time - would love one in Asia, Central/South America, and South Pacific.
Thanks,
Alex
On 09/06/2011 04:02 PM, Cameron Shorter wrote:
> On 7/09/2011 8:28 AM, Hamish wrote:
>> Cameron:
>>> However, I suggest changing the 1 image in the docs before
>>> releasing to the generic background.
>> Alex:
>>>>     Do we really need to change the screenshot in
>>>> the docs if we change the background only slightly
>>> (doesn't seem like a big deal to me)
>> Cameron:
>>> I suggest that we should, but it is quite simple to do. We
>>> only need to change 1 file from:
>>> doc/images/screenshots/800x600/osgeolive_menu.png
>>> to
>>> https://svn.osgeo.org/osgeo/livedvd/gisvm/branches/osgeolive_5_0/doc/images/screenshots/800x600/osgeolive_menu.png
>> While cosmetic thing, I'd prefer it if that particular screen-
>> shot be taken with the cursor visible, and an item selected from
>> the menu*. Also since it is our front-window display image, I'd
>> ask that it be taken with the desktop icons cleaned up and no
>> stray apps running in the task bar. (so taken from the VM not
>> the ISO)
>> [*] learn from the greek masters: instill a sense of movement
>> in your static display to engage the viewer's mind.
>> If no one else gets to it first I'll try for a cleaned up version
>> over lunch.
> Hamish, good idea.
> It will be ~ 12 hours before I can get to it, so sounds like you will
> beat me.
>> thanks,
>> Hamish
>> ps- when committing to the release branch, please try to merge
>> between svn branches instead of committing the same file/change
>> as new, twice. see the svn instructions on the wiki for details
>> how.
> I did use a "svn merge" to copy this image into the 5.0 branch, although
> I'm not sure how my use translated into the svn repository. I did:
> cd branches/5.0/doc/images
> svn merge https://svn.osgeo.org/osgeo/livedvd/gisvm/trunk/doc/en/images
> svn diff
> svn commit
> Which I see is slightly different to wiki at:
> http://wiki.osgeo.org/wiki/Live_GIS_Build#Merging but I assumed should
> produce the same results?
More information about the Live-demo mailing list
