[Live-demo] Replacing existing Ubuntu installation with Live Demo
Hamish hamish_b at yahoo.com
Sat Sep 24 22:37:01 EDT 2011
Kurt wrote:
> Hello,I have a Dell laptop with a dual boot setup between
> Windows XP and Ubuntu 11.04.  I'd like to replace my existing
> Ubuntu installation with the OsGeo Live DVD and am trying to
> figure out the most elegant way to do this.
install the apps you want to your existing ubuntu install using
the provided install scripts,  (see below)
> I thought I could just boot up the DVD and choose the Install
> option and pick my Ubuntu partition and install.
that will wipe out + replace your ubuntu installation with xubuntu 11.04, not augment it. if your ubuntu boot is fresh out
of the box, maybe it is no trouble to start again from scratch?
> However, I'm not sure what to set in the Allocate drive space
> window during the install.  The Ubuntu partition is /dev/sda4
> fat32.
fat32? typically it would be ext4 or ext3 unless it was installed
with the "install to bootable usb" method, which is not needed
for a real hard drive.
> I'm not sure if I just select that partition and click Install
> Now, or if I need to have it Format that partition.  It doesn't
> let me check that format box.   Is there another way to install
> this via apt-get from my existing Ubuntu installation?
as per http://wiki.osgeo.org/wiki/Live_GIS_Build#Getting_started
boot into ubuntu,
make sure subversion is installed:
 sudo apt-get install subversion
then fetch the livedvd build scripts:
 svn checkout https://svn.osgeo.org/osgeo/livedvd/gisvm/trunk osgeo_live
cd into the bin dir:
 cd osgeo_live/bin
and either install everything (will take some time!) with
 ./main.sh
or, just the particular project(s) you are interested in:
 ./install_marble.sh
(in the case you just install individual projects, you may need
to take care of prerequisites by running other install scripts
like install_apache2.sh first)
good luck,
Hamish
More information about the Live-demo mailing list
