[Live-demo] Planing Roadmap in OSGeo Trac for Live Project
Alex Mandel tech_dev at wildintellect.com
Mon Apr 2 19:42:27 EDT 2012
It's not a matter of admin access. More that those milestones would be
confusing to anything filed on that trac instance that wasn't osgeo-live
related, aka SAC tickets.
We could add them or we could look into an independent trac instance.
Someone will need to research how to export a portion of the tickets,
and only a subdir of the svn.
Thanks,
Alex
On 04/02/2012 02:09 PM, Frank Gasdorf wrote:
> Just a short answer for the moment,
> With the osgeoid its possible to login and create new tickets
> (http://trac.osgeo.org/osgeo/newticket) but I miss the version filed
> as well, which can be administration as a combo box with the already
> released versions. In addition admin section for the trac is not
> accessible for everybody, means, that its possible for users with an
> osgeo id to configure (add/rename versions or add milestones). I guess
> because of the multi-project trac instance it could be it limited that
> only osgeo admins can change something like this. One more reason to
> setup a different trac/subversion pair for the osgeo live project.
> Cheers
> - Frank
> 2012/4/2 Cameron Shorter <cameron.shorter at gmail.com>:
>> Issue Tracker
>> Our issue tracker is hosted at OSGeo's Trac system, and you will need to
>> create an OSGeo UserId before you can login and edit issues. To distinguish
>> the LiveDVD project from other OSGeo projects, use the following
>> conventions:
>> Component field
>>     Set to `LiveDVD`
>> Keywords
>>     Version: Set to base release version: eg: 5.0, 5.5 (not 5.5rc1)
>>     Application: Set to application with issue (use lower case): eg:
>> "geoserver"
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
> http://live.osgeo.org
> http://wiki.osgeo.org/wiki/Live_GIS_Disc
More information about the Live-demo mailing list
