[Live-demo] Planing Roadmap in OSGeo Trac for Live Project
Frank Gasdorf fgdrf at users.sourceforge.net
Tue Apr 3 03:37:04 EDT 2012
Absolutely agree, its not necessary to setup a new trac instance and
an other subversion repo.
Version pattern would be the same as used for the live dvd itself :
'OSGeo-Live 5.x'
I would suggest to use this pattern for milestones and for SVN tags as
well, optionally appended by a 'RCx'
But the questions is, who can create a milestone (which we could
delete later if we don't want to use this trac feature)?
Cheers,
Frank G.
2012/4/3 Frank Warmerdam <warmerdam at pobox.com>:
> Folks,
> Note that we could add OSGeo Live related milestones and  versions in
> the generic OSGeo trac as long as we prefixed them with live- or
> something like that to make it clear where they apply.
> Best regards,
> On Mon, Apr 2, 2012 at 4:42 PM, Alex Mandel <tech_dev at wildintellect.com> wrote:
>> It's not a matter of admin access. More that those milestones would be
>> confusing to anything filed on that trac instance that wasn't osgeo-live
>> related, aka SAC tickets.
>> We could add them or we could look into an independent trac instance.
>> Someone will need to research how to export a portion of the tickets,
>> and only a subdir of the svn.
>> Thanks,
>> Alex
>> On 04/02/2012 02:09 PM, Frank Gasdorf wrote:
>>> Just a short answer for the moment,
>>> With the osgeoid its possible to login and create new tickets
>>> (http://trac.osgeo.org/osgeo/newticket) but I miss the version filed
>>> as well, which can be administration as a combo box with the already
>>> released versions. In addition admin section for the trac is not
>>> accessible for everybody, means, that its possible for users with an
>>> osgeo id to configure (add/rename versions or add milestones). I guess
>>> because of the multi-project trac instance it could be it limited that
>>> only osgeo admins can change something like this. One more reason to
>>> setup a different trac/subversion pair for the osgeo live project.
>>> Cheers
>>> - Frank
>>> 2012/4/2 Cameron Shorter <cameron.shorter at gmail.com>:
>>>> Issue Tracker
>>>> Our issue tracker is hosted at OSGeo's Trac system, and you will need to
>>>> create an OSGeo UserId before you can login and edit issues. To distinguish
>>>> the LiveDVD project from other OSGeo projects, use the following
>>>> conventions:
>>>> Component field
>>>>     Set to `LiveDVD`
>>>> Keywords
>>>>     Version: Set to base release version: eg: 5.0, 5.5 (not 5.5rc1)
>>>>     Application: Set to application with issue (use lower case): eg:
>>>> "geoserver"
>>> Live-demo mailing list
>>> Live-demo at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/live-demo
>>> http://live.osgeo.org
>>> http://wiki.osgeo.org/wiki/Live_GIS_Disc
> I set the clouds in motion - turn up   | Frank Warmerdam, warmerdam at pobox.com
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush    | Geospatial Software Developer
More information about the Live-demo mailing list
