[Live-demo] GEOS image for OSGeo-Live Overview
Cameron Shorter cameron.shorter at gmail.com
Tue Apr 3 16:08:14 EDT 2012
Martin,
I'll answer your 2 questions in 2 email threads, to make it easier to
follow.
Thanks for the offer for your image JTS image. We will need a larger
image so it sounds like someone will need to create it. Any volunteers
lurking wishing to offer to create something like:
http://tsusiatsoftware.net/jts/images/example-intersection.gif
in a 1024x768 image?
On 02/04/12 09:40, Martin Davis wrote:
> Cameron,
> I'm fine with using that image (or image idea) for the GEOS image.
> I don't have a larger version - it would have to be recreated.  This
> would be fairly easy to do using the JTS TestBuilder, which can export
> to PNG.  But I won't have time to do that until after FOSS4G - I"m
> pretty busy beforehand!
> Are the questions about JTS at OSGeo and on OSGeo-Live two separate
> questions?  8^)  I did have a short discussion with Frank in Denver
> about bringing JTS into OSGeo.  I think he was concerned that it could
> not meet the acceptance criteria, such as having a wider developer
> community.  But if it can be included on OSGeo-Live in spite of that,
> I'm happy for that to happen.
> HTH - Martin
> On Sun, Apr 1, 2012 at 1:38 PM, Cameron Shorter
> <cameron.shorter at gmail.com <mailto:cameron.shorter at gmail.com>> wrote:
>     On 02/04/12 04:02, Frank Warmerdam wrote:
>             Frank, do you have suggestions for a GEOS image?
>         Possibly something like this:
>         But that is already used for JTS so it might be a cop-out to
>         grab it.
>     Martin,
>     I suspect that you would have been the original creator of the
>     image Frank references above?
>     Do you have any objection to it being used in conjunction with GEOS?
>     Maybe we could have 2 variants on the same image, one for JTS, the
>     other for GEOS?
>     Do you have a larger version of the image? It needs to be 1024x768
>     for osgeo docs.
>     This does lead to a later question, about bringing JTS into OSGeo
>     and OSGeo-Live. (We aim to include descriptions of all OSGeo
>     library projects on OSGeo-Live.)
>     Cameron Shorter
>     Geospatial Solutions Manager
>     Tel: +61 (0)2 8570 5050 <tel:%2B61%20%280%292%208570%205050>
>     Mob: +61 (0)419 142 254 <tel:%2B61%20%280%29419%20142%20254>
>     Think Globally, Fix Locally
>     Geospatial Solutions enhanced with Open Standards and Open Source
>     http://www.lisasoft.com
Cameron Shorter
URL: http://lists.osgeo.org/pipermail/live-demo/attachments/20120404/0da54d6f/attachment.html
More information about the Live-demo mailing list
