[Live-demo] Fw: Re: [SAC] [OSGeo] #1001: Failed to install
Hamish hamish_b at yahoo.com
Wed Aug 29 02:50:36 PDT 2012
@everyone: please be sure to set the Component to "LiveDVD" when you are
creating a ticket, and to reply to the appropriate mailing list :o)
thanks,  Hamish
--- On Tue, 8/28/12, cgdnorth  wrote:
> From: cgdnorth
> Subject: Re: [SAC] [OSGeo] #1001: Failed to install
> To: sac lists.osgeo.org
> Date: Tuesday, August 28, 2012, 11:17 AM
> I am having the same problem. I tried
> to install the full version of
> osgeo-live-6.0.iso.
> I tried on a drive partitioned with Ubuntu on it as well as
> a new 360Gb
> 7200rpm drive. The computer is a dual core Dell Inspiron
> 1420 with 4Gb ram.
> I am get the following crash report:
> ExecutablePath
>  /usr/lib/ubiquity/bin/ubiquity
> Package
>  ubiquity 2.10.20
> ProblemType
>  Crash
> Title
>  ubiquity crashed with ValueError in the install_size():
> invalid literal for
> int() with base 10:''
> Traceback
>  Traceback (most recent call last):
>   File "/usr/lib/ubiquity/frontend/gtk_ui.py",line 701,
> in <lambda>
>    GObject.idle_add(lambda:
> self.dbfilter.start(auto_process=True))
>  File "/usr/lib/ubiquity/ubiquity/filtercommand.py", line 90
> in start
>   prep = self.prepare()
>  File "/usr/lib/ubiquity/plugins/ubi-prepare.py", line 227,
> in prepare
>   self.setup_sufficient_space()
>  File "/usr/lib/ubiquity/plugins/ubi-prepare.py", line 232,
> in
>   size=misc.install_size()
>  File "/usr/lib/ubiquity/ubiquity/misc.py", line 791, in
> install_size
>   size=int(fp.readline())
>  ValueError: invalid literal for int() with base 10:"
> There is more but I didn't want to type the entire thing
> out.
> I will try the osgeo-live-mini-6.0.iso version and see if
> that gives the
> same error.
> Chris
> View this message in context: http://osgeo-org.1560.n6.nabble.com/OSGeo-1001-Failed-to-install-tp4998135p4998386.html
> Sent from the OSGeo System Administration Committee mailing
> list archive at Nabble.com.
> Sac mailing list
> Sac at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/sac
More information about the Live-demo mailing list
