[Live-demo] Re-categorising OSGeo-Live projects
    Cameron Shorter
    cameron.shorter at gmail.com
    Mon Dec 17 02:37:26 PST 2012
Peter, each application is only mentioned once, (the 52 North team have
built a number of stand alone applications, all with the same naming
convention).
It is tempting to have a number of duplicates, or maybe use tags, but I
think it more important to keep it simple.
Noting that:
* The primary purpose of this list is a "Table of Contents"
* It needs to be simple enough for new users to understand on first glimpse
* It needs to be simple enough to translate without complications
* It needs to be reasonably static to reduce long term maintenance
(especially long term translation effort)
On 17/12/2012 10:17 AM, Peter Baumann wrote:
> hm, while I still find that Web Services in this field mostly are data
> services, I'm looking into the classification again finding that, eg,
> 52north is listed multiply. Therefore, let me suggest to resolve the
> dichotomy with
> - Web services:
>     rasdaman/petascope -- WMS, WCS, WCPS, WCS-T, and WPS server
> - Data store:
>     rasdaman - multidimensional raster database
> -Peter
> On 12/16/2012 08:56 PM, Cameron Shorter wrote:
>> Categorisation is only ever going to be a rough best guess that won't
>> fit all cases, but better to have than nothing. It is also based on
>> user perception. If my main purpose for rasdaman is to run SQL
>> queries on it, then I'd categorise it as a DataStore. If it is
>> largely used for WPCS and WPS, then Web Services is better.
>> I still have a mild preference for categorising Rasdaman as a Web
>> Service, but will keep the categorisation as Data Store unless Peter
>> tells me otherwise.
>> On 17/12/12 06:44, Peter Baumann wrote:
>>> I'm completely on board about MapServer - actually, in my
>>> classification sketched below it is a service indeed, whereas DBMSs
>>> form another category of services. BTW, MapServer is not a Web
>>> server either - it needs Apache or similar to run. But it offers
>>> WCS, just like rasdaman (a DBMS) does, for example.
>>> Both categories, whether filebased or using databases, serve data
>>> over the Web in the end, and both offer overlapping services (such
>>> as WMS, WCS); the difference is the paradigm of management.
>>> cheers,
>>> Peter
>>> On 12/16/2012 07:05 PM, Stefan Steiniger wrote:
>>>> well, but I would not count MapServer as a DBMS,
>>>> If a DBMS has service functions and supports services, then so be
>>>> it, but it still is a DBMS and not a Web-Server... or? I.e. one is
>>>> to manage data and the other is to serve data over the internet.
>>>> maybe?
>>>> Am 16.12.12 17:44, schrieb Peter Baumann:
>>>>> Cameron-
>>>>> sorry for the silence, just now I can come back on this again.
>>>>>  From a client perspective, we share WCS support; the differentiating
>>>>> criterion I see as follows (EOX, please correct if necessary):
>>>>> - EOxServer's main mission is EO-WCS, and it also supports WCS;
>>>>> - rasdaman's main mission is WCPS, and it also supports WCS (being
>>>>> candidate reference implementation for WCS Core).
>>>>> Now we have 2 categories, "services" and "data stores", which clearly
>>>>> overlap - essentially, any DBMS is a potential service as well. Also,
>>>>> both file-based and DBMS-based stores offer OGC services, so again a
>>>>> difficult distinction. Finally, the "Web Services" also store
>>>>> their data
>>>>> somehow :) so "Storing spatial data"this is not a clear criterion
>>>>> either.
>>>>> Hence, a suggestion: introduce 2 service categories (I think
>>>>> service is
>>>>> a main aspect of this whole category):
>>>>> - file-based services
>>>>>      MapServer -- as an example
>>>>> - database-backed services
>>>>>      rasdaman -- multi-dimensional raster database offering OGC WMS,
>>>>> WCS, WCS-T, WCPS, and WPS
>>>>> Just some thought,
>>>>> Peter
>>>>> On 12/12/2012 11:04 PM, Cameron Shorter wrote:
>>>>>> Peter,
>>>>>> Coming back to this question of categorisation. It seems that
>>>>>> EOxServer is similar to Rasdaman, and probably should be listed next
>>>>>> to it? Is that reasonable?
>>>>>> If so, should both EOxServer and Rasdaman be categorised under "Data
>>>>>> Stores" or under Web Services?
>>>>>> To make that decision, I'd consider how people are most likely to
>>>>>> access each application. If it is via a Web Service, then I'd err
>>>>>> toward a Web Service categorisation.
>>>>>> On 10/12/12 07:14, Angelos Tzotsos wrote:
>>>>>>> I agree with Peter: rasdaman is better categorized under DBMS.  OGC
>>>>>>> web services are extra functionality in rasdaman.
>>>>>>> Best,
>>>>>>> Angelos
>>>>>>> On 12/09/2012 09:34 PM, Peter Baumann wrote:
>>>>>>>> Cameron-
>>>>>>>> re rasdaman, it is a DBMS indeed, in the same category as PostGIS.
>>>>>>>> For example, rasdaman comes with a multi-dimensional
>>>>>>>> spatio-temporal
>>>>>>>> query language; in terms of OGC standards, WCS is just one rather
>>>>>>>> limited functionality, there's also WMS, WCPS, and WPS.
>>>> _______________________________________________
>>>> Live-demo mailing list
>>>> Live-demo at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/live-demo
>>>> http://live.osgeo.org
>>>> http://wiki.osgeo.org/wiki/Live_GIS_Disc
Cameron Shorter
Geospatial Solutions Manager
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
More information about the Live-demo
