[Live-demo] Build Process - Filesystems
Patric Hafner | geOps
patric.hafner at geops.de
Fri Dec 21 02:17:26 PST 2012
Dear Members of the OSGeo mailing list,
in last days, I run the build process as described here [1] several
times to test our install script. Unfortunately the building always
failed due to problem with unmouting of dev and proc-filesystem for
chroot. After some small changes, I was able to fix this issue.
Do someone else also experienced those problems?
For me it is not obvious why it is necessary to bind the whole /dev into
the chroot - /dev/pts should do it. Secondly, it seems more safe to me,
to execute the mount of /proc outside the chroot.
After performing the following changes, building runs always fine in my
environment.
*build_chroot_debug.sh*
-- sudo mount --bind /dev/ edit/dev
++ sudo mount -t proc -o bind /proc edit/proc
++ sudo mount -o bind /dev/pts edit/dev/pts
-- sudo umount edit/dev
++ sudo umount edit/dev/pts
++ sudo umount edit/proc
*inchroot_debug.sh*
--mount -t proc none /proc
--mount -t sysfs none /sys
--mount -t devpts none /dev/pts
-- umount /proc || umount -lf /proc
-- umount /sys
-- umount /dev/pts
Any comments or ideas ?
[1]
http://wiki.osgeo.org/wiki/Live_GIS_Build#How_to_do_development_.2F_debugging_with_the_current_build_method
With best regards,
Patric Hafner
geOps e.K.
Handelsregister A 702785, Amtsgericht Freiburg
Kaiser-Joseph-Strasse 263
D-79098 Freiburg
fon +49 761 503 126 91
fax +49 761 503 126 94
free service calls from D and CH
00800 436 436 436
web www.geops.de
rss www.geops.de/blog/feed
follow www.twitter.com/geops_tweet
More information about the Live-demo
