[Live-demo] [OSGeo] #1032: GeoNetwork freezes when memory is 1GB or less
OSGeo
trac_osgeo at osgeo.org
Sun Dec 30 09:42:26 PST 2012
Reporter: kalxas | Owner: live-demo@…
Type: defect | Status: new
Priority: normal | Milestone: OSGeoLive6.5
Component: LiveDVD | Keywords: 6.5 alpha 4
Changes (by kalxas):
* priority: major => normal
Comment:
After more testing and some feedback from the GeoNetwork team, these are
the new findings:
1. GeoNetwork works fine when booting iso on real hardware (tested on my
1GB RAM netbook)
2. The service starts fine under a VM with 1GB RAM but then freezes the
system when Firefox tries to show the main page. This issue seems to be VM
specific. Perhaps there is a memory overhead due to low quality graphics
card?
3. GeoNetwork team suggested to check the Java memory settings and define
512 MB, which was already set in the setting file.
4. When I do "sudo service tomcat6 stop" before starting GeoNetwork's
Jetty, everything works fine.
So my conclusion is that default tomcat + GN jetty on 1GB RAM bring down
the system due to lack of swap space. On the other hand, other Jetty
instances require less memory and work fine along with default tomcat.
Thoughts? Perhaps we should document this somewhere in the docs? I would
suggest NOT to change minimum RAM requirements, it would reflect bad on
OSGeoLive requesting more than 1GB RAM in my opinion, especially when our
base OS requires 256MB.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/1032#comment:1>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo
