[Live-demo] 5.5 Beta 2 Status
Angelos Tzotsos gcpp.kalxas at gmail.com
Sun Feb 5 21:49:30 EST 2012
On Mon, Feb 6, 2012 at 3:02 AM, Hamish <hamish_b at yahoo.com> wrote:
> Hi,
> Angelos wrote:
> > I started the testing process and it seems we have some
> > problems here:
> > The bin directory seems to have a problem since "svn up" does
> > not seem to work.
> the .svn/ dirs were being removed by build_iso.sh. I've
> temporarily disabled that in r7507 but it should be turned
> back on for the final build to save space.
> ok, this is a good solution for testing using the betas
> > This problem seems to have taken down all docs as well...
> The docs failed because MapGuide left the dpkg system in a
> broken state, so install_main_docs.sh could not 'apt-get install'
> the tools it needed to run.
> should we leave the beta2 without docs? or go to a next beta3 soon?
> > Deegree, Geonetwork, Rasdaman do not start
> deegree: will have to wait until the next build (fixed ports)
ok
> geonetwork: any error message? what happens? the install log
> looks ok to me.
> perhaps it was a memory thing or a tomcat failure. I will test again and
report back on this
> rasdaman: didn't install due to broken R repository, next build..
ok
> > All other applications seem to be fine.
> great. do you see the 'pink tile' problem with MapFish?
> is that just when it is tested off-line?
> this is just when offline. It was there in previous stable releases.
Obviously the project did not want to rely on installed servers that might
not be turned on during runtime and chose an online server
> > Another weird behavior was loosing ssh after first restart
> > during build process. Perhaps apt-get autoclean removed the
> > ssh server...
> we remove the unique keys on purpose before creating the ISO.
> (if not it wouldn't be so unique once duplicated...)
> see
>  http://wiki.osgeo.org/wiki/Live_GIS_Disc_FAQ#Administration
> the problem was not unique keys but complete rejection of connections. I
tested with 2-3 other machines...
> thanks,
> Hamish
cheers,
Angelos
Angelos Tzotsos
Remote Sensing Laboratory
National Technical University of Athens
http://users.ntua.gr/tzotsos
URL: http://lists.osgeo.org/pipermail/live-demo/attachments/20120206/1a1013a2/attachment.html
More information about the Live-demo mailing list
