[Live-demo] Re: creating live dvd with custom workshop materials
Alex Mandel tech_dev at wildintellect.com
Tue Feb 7 18:20:44 EST 2012
Remastersys is tricky. I didn't realize your goal was to make an ISO
from the USB stick. I'm not sure that will work. Normally we would
suggest you use a Virtual Machine to make the ISO, since you need to
have 4 GB of writable space available for the resulting image.
Yes, as you discovered not all methods of making a bootable usb result
in "persistent storage" or "persistence" which is the ability to save
changes to the extra space on the drive (outside the ISO file).
Thanks,
Alex
On 02/07/2012 03:09 PM, Cameron Shorter wrote:
> Apparently there are a few tricks with building a USB. As mentioned,
> Alex is the expert, and he mentioned on IRC that he was looking into it
> for you.
> Also, would you mind adding an entry into our history section, as
> demonstrated use of osgeo-live is what keeps our contributors motivated:
> http://wiki.osgeo.org/wiki/Live_GIS_History
> On 08/02/12 09:31, Kurt Menke wrote:
>> Hi Cameron,
>> I never did get pendrivelinux to work. I used Make Startup Disk on my
>> ubuntu box and it worked perfectly. I was also able to get my
>> materials onto the resulting thumb drive.
>> Now I'm in the final step of trying to create an ISO from the bootable
>> thumb drive. My goal is to create several bootable DVD's for
>> participants. I'm trying to use remastersys and it finishes, but the
>> ISO isn't created. Any thoughts on that?
>> Believe it or not I've never used IRC but will try to get on and ask
>> there too.
>> Thanks.
>> Kurt
>> Kurt Menke, GISP
>> Bird’s Eye View
>> www.BirdsEyeViewGIS.com <http://www.birdseyeviewgis.com/>
>> Work: 505-265-0243
>> Cell: 505-362-1776
> Cameron Shorter
> Geospatial Solutions Manager
> Tel: +61 (0)2 8570 5050
> Mob: +61 (0)419 142 254
> Think Globally, Fix Locally
> Geospatial Solutions enhanced with Open Standards and Open Source
> http://www.lisasoft.com
More information about the Live-demo mailing list
