[Live-demo] Re: [OSGeo] #855: Panel menus
OSGeo trac_osgeo at osgeo.org
Thu Feb 9 03:53:03 EST 2012
#855: Panel menus
 Reporter:  micha    |       Owner:  hamish
     Type:  task     |      Status:  assigned
 Priority:  normal   |   Milestone:
Component:  LiveDVD  |    Keywords:  5.5 panel menus
Comment(by hamish):
 [tested with 5.5beta3 VM]
 if you create a new user with 'sudo adduser yourname', then log in as you
 your new account gets the Apps & Geospatial menus on the top taskbar, the
 keyboard switcher applet, etc, all ok (so the skeleton files are ok). So
 it's just the local `user` which has lost that and the fix is probably
 just a little tweak..
 in the "what changed?" dept: is there some difference in the way that Alex
 used to create the VM and the current build? (i.e. had the "user" logged
 in to a xfce session prior to the osgeo install scripts running? [and so
 already generated the desktop files in ~/.config etc])
 Hamish
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/855#comment:2>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo mailing list
