[Live-demo] duplicating bootable flash drive
Cameron Shorter cameron.shorter at gmail.com
Mon Feb 13 14:50:56 EST 2012
Alex,
Can we please capture everything we know about USB creation into a howto
in our wiki, so we can point people at it.
On 14/02/2012 4:43 AM, Alex Mandel wrote:
> On 02/13/2012 08:28 AM, Kurt Menke wrote:
>> Hello,
>> I have created a bootable flash drive from the OSGeo-LiveDVD-5.0.iso&  I'd
>> like to make 20 copies of it.
>> How can I duplicate the drive? There's obviously more to it than just
>> copying all the files from one drive to another. When I do that and try to
>> use the new drive to boot from I just get a disc error.
>> Kurt
> Sure part of the process includes partitioning and set the boot flag on
> the partition. Not things a copy can do. Usually you'll have to repeat
> the same procedure you used on the 1st drive using the usb creator tools.
> You might be able to write a script that uses fdisk and dd if you want
> to get fancy with it. FYI, we discovered at Foss4g when we had to redo
> all of them that you can do 2 at a time, and if you do the usb creation
> from Linux it only takes 6-10 minutes where windows takes 30-60 minutes.
> Thanks,
> Alex
> Live-demo mailing list
> Live-demo at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/live-demo
> http://live.osgeo.org
> http://wiki.osgeo.org/wiki/Live_GIS_Disc
Cameron Shorter
Geospatial Solutions Manager
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
More information about the Live-demo mailing list
