[Live-demo] Re: Should 52 North WPS continue to be included on OSGeo-Live?
Bastian Schäffer b.schaeffer at 52north.org
Fri Feb 17 02:37:14 EST 2012
Hi Angelos,
yes, good idea. The external WFS is a geoserver and a default dataset is
used.
So my question:
- How was the WPS tested? Leading to: Where is the request with the
outdated WFS URL located?
Regards,
Bastian
Am 17/02/2012 00:46, schrieb Angelos Tzotsos:
> Hi Bastian and thanks for the feedback.
> Perhaps you could use a GeoServer WFS layer from within the DVD, like
> Zoo-Project does for its demo.
> Regards,
> Angelos
> On 02/17/2012 12:58 AM, Cameron Shorter wrote:
>> Thanks for the feedback Bastian,
>> So we have a couple of issues here:
>> 1. The LiveDVD is referencing an external URL, which means it won't
>> work when offline. We aim to have the DVD work even when offline.
>> Is it possible to make use of a locally installed URL in its place?
>> 2. If we can't get a local URL set up, who owns the broken URL:
>> http://giv-wps.uni-muenster.de:8080/
>> Can we either get it back online, or alternatively, find a more
>> stable URL to replace it with?
>> On 17/02/2012 9:23 AM, Bastian Schäffer wrote:
>>> Hi Cameron,
>>> Hamish is right, the "problem" is the external WFS. So, the WPS
>>> server is fine (and has not changed). The test requests you send
>>> contain a non working data link to an external WFS.
>>> How do you test if some server is working?
>>> How can we change the
>>> Regards,
>>> Bastian
>>> Am 16.02.2012 um 23:04 schrieb Cameron
>>> Shorter<cameron.shorter at gmail.com>:
>>>> We have one week before we cut our final release of OSGeo-Live 5.5
>>>> (25 Feb), and the 52 North WPS is the only application left which
>>>> doesn't work. If we can't get it working in the next couple of
>>>> days, we are going to have to remove it from the next osgeolive
>>>> release.
>>>> As yet, we haven't been able to connect with anyone from 52 North
>>>> to discuss this.
>>>> Can you please:
>>>> 1. ASAP: Send a response to this email, confirming that someone in
>>>> 52N has received this email.
>>>> 2. Within 24 hours: Note whether you wish 52 North WPS to be
>>>> included on the next OSGeo-Live release.
>>>> 3. Within 3 days: Assuming we should keep 52N WPS, help us debug
>>>> the issue and find a resolution.
>>>> We have an issue description here:
>>>> https://trac.osgeo.org/osgeo/ticket/859
>>>> You can usually find one of our osgeolive developers online at:
>>>> irc://freenode.net#osgeolive
>>>> And our email list is: live-demo at lists.osgeo.org
>>>> Cameron Shorter
>>>> Geospatial Solutions Manager
>>>> Tel: +61 (0)2 8570 5050
>>>> Mob: +61 (0)419 142 254
>>>> Think Globally, Fix Locally
>>>> Geospatial Solutions enhanced with Open Standards and Open Source
>>>> http://www.lisasoft.com
Dr. Bastian Schäffer
52° North Initiative for Geospatial Open Source Software GmbH
Martin-Luther-King-Weg 24
Fon: +49-(0)-251–396371-41  Fax: +49-(0)-251–396371-11
email: schaeffer at 52North.org
52North-site: http://www.52North.org
General Managers: Dr. Albert Remke, Dr. Andreas Wytzisk
Local Court Muenster HRB 10849
More information about the Live-demo mailing list
