[Live-demo] Re: Please check the updated USB quickstart
Alex Mandel tech_dev at wildintellect.com
Wed Feb 22 16:16:07 EST 2012
On 02/22/2012 11:43 AM, activityworkshop wrote:
> Hi,
> Yep, that pretty much describes what I already did. The only sentence I
> find confusing is this one:
> If using a DVD, then put the DVD into the DVD drive.
> I'd leave this sentence out completely, because you're already running
> ubuntu, you've already downloaded the iso to the hard drive, and you've
> plugged in the usb stick - that's all you need.
> Oh, and if you're running ubuntu, then the path to the startup disk
> creator isn't "System - Administration - Startup disk creator" (or even
> "Applications - System - Startup disk creator" as in your screenshot).
> In the default Ubuntu live system you don't get a programs menu like
> that at all, just a place to type in a search term. See for example
> this screenshot:
> http://cdn.omgubuntu.co.uk/wp-content/uploads/2011/08/dash.jpg
> or search for "ubuntu 11.10 dash". I don't know a clear way to describe
> it, but it's pretty different from the start menus most people are
> familiar with.
Good point, those instructions are based on gnome. I'll revise the wiki
for XFCE which is what we ship. The terminal method should work on XFCE.
Thanks,
Alex
More information about the Live-demo mailing list
