[Live-demo] Where should JAVA_HOME be set (if overriding default=openjdk 1.7)?
edgar.soldin at web.de edgar.soldin at web.de
Sun Jan 15 16:35:23 EST 2012
np...
does the osgeo live-dvd set a JAVA_HOME env var? if yes where? the switcher would have to change it.
..ede
On 15.01.2012 20:59, Cameron Shorter wrote:
> Edgar,
> Thank you very much, if this works, (which I assume it does), it will be very useful.
> Would you mind also including a script: install_java_switcher.sh, which would create java_switcher.desktop and update the suders file. I suggest that switch.sh would be easier to recognise if called java_switcher.sh.
> Please also add a Copyright header, like all the other scripts, so that we know the author (yourself) has given us rights to use this script with OSGeo.
> The scripts should be put into trunk/bin in the osgeo svn directory.
> If you can add the scripts to svn, then I'll test them.
> FYI, the current directory structure on osgeo live is:
> user at osgeo-live:~$ ls -l /usr/lib/jvm
> total 8
> lrwxrwxrwx  1 root root   19 2011-08-25 19:50 java-6-sun -> java-6-sun-1.6.0.26
> drwxr-xr-x  8 root root 4096 2011-08-25 19:51 java-6-sun-1.6.0.26
> drwxr-xr-x 10  500  500 4096 2011-06-27 03:02 jdk1.7.0
> On 15/01/12 01:17, edgar.soldin at web.de <mailto:edgar.soldin at web.de> wrote:
>> find attached a proof of concept. for testing purposes i switched between openjdk6/7.
>> it needs an entry in /etc/sudoers
>> user   ALL=(ALL) NOPASSWD: /home/user/switch.sh
>> attached files go to
>> /home/user/Desktop/java.desktop
>> hamish probably has some idea where to place which file.
>> ..ede
>> Live-demo mailing list
>> Live-demo at lists.osgeo.org <mailto:Live-demo at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/live-demo
>> http://live.osgeo.org
>> http://wiki.osgeo.org/wiki/Live_GIS_Disc
> Cameron Shorter
> Geospatial Solutions Manager
> Tel: +61 (0)2 8570 5050
> Mob: +61 (0)419 142 254
> Think Globally, Fix Locally
> Geospatial Solutions enhanced with Open Standards and Open Source
> http://www.lisasoft.com
More information about the Live-demo mailing list
