[Live-demo] Where should JAVA_HOME be set (if overridingdefault=openjdk 1.7)?
maplabs at light42.com maplabs at light42.com
Mon Jan 16 14:53:54 EST 2012
Hi Cameron - thx for your work on this
On Tue, 17 Jan 2012 06:38:04 +1100, Cameron Shorter
<cameron.shorter at gmail.com> wrote:
So to cover all scenarios we want to test, I suggest we do the following:
> JAVA_HOME defaults to SunJava globally, then:
> Case 1: Project has confirmed application runs in OpenJDK.
> * Application's start script sets JAVA_HOME=OpenJDK
> * We test app with OpenJDK
> Case 2: Project hasn't confirmed application runs in OpenJDK, or says
> only runs in SunJava
> * Application doesn't set JAVA_HOME, so it defaults to SunJava
> * Test 1: with SunJava
> * User can then change JAVA_HOME to OpenJDK, then rerun the
> application start script
> * Test 2: with OpenJDK
> * Verify OpenJDK is running by running "ps aux | grep java" or similar
not quite.. a key is the "update-alternatives" mechanism in Ubuntu
Without knowing much about how it works, I gather that we have to
change that value *first*, then set environment vars, then call the app
It appears you are starting a set of instructions for testers..
Perhaps someone that is familiar with java behavior can go through the
exercise of actually switching "update-alternatives" and doing whatever
else to run, and report back, before sending less-skilled people to test
  -Brian
> On 17/01/2012 12:36 AM, edgar.soldin at web.de wrote:
> > On 16.01.2012 04:55, Hamish wrote:
> >> Hamish wrote:
> >>> a systemwide exchange of all java components should be done
> >>> properly, true. simply i tried never to achieve that and
> >>> although bruno reis gives a good introduction later i
> >>> definitely think that would be wasted effort.
> >> if our needs are simply to swap it out during beta-testing
> >> then we don't really need to also swap out the man pages and
> >> ancillary stuff, just the JVM binary, so I'd guess much of
> >> Bruno's long list could be ignored and it collapses to:
> >> sudo update-alternatives --set java /usr/lib/jvm/java-7-sun/jre/bin/java
> >> or something like that.
> > should be worth a try. we might stumble over complications like
> mentioned in comments below on that page, but supposedly this would
> be the proper way. but again, if we run into issues with browser
> components or such i really say why bother. simply exchanging the
> binary link does it (at least for testing images).
> >>>> run-time scripts (as opposed to build-time scripts)
> >>>> should go into gisvm/trunk/app-conf/java/ and
> >>>> be copied into /usr/local/bin/ by the bin/install_*
> >>>> script.
> >>> could do so, if you want to. i feel some rejection on your
> >>> part, which i can definitely understand.
> >> just a personal opinion, explore the task or not as you enjoy.
> >> The only caveat is if things aren't working 100% by release-
> >> candidate time, and it comes down to me fixing it, fair warning
> >> that system stability takes precedence and things will revert
> >> back to the simple/built-in solutions.
> > as mentioned. it was meant as a proof of concept for the testers.
> in hindsight, communicating the options namely setting env var or
> switching java alternative should suffice.
> > btw. i actually do not expect lot's of java apps to choke on openjdk7.
> >>> telling all java
> >>> projects to set proper JAVA_HOMEs in their launch scripts
> >>> (do all java apps use scripts?) would achieve the same with
> >>> less effort.
> >>> so, any one else an opinion?
> >>> btw. i'd agree to have the java projects to adapt their
> >>> launchers manually. they have to do so anyway.
> >> I guess hardcoding it depends on how solidly they know it works
> >> with ver 7 or not. better to only hardcode it in dire situations
> >> though.
> > exactly my point ;)
> > thanks ede
> > Live-demo mailing list
> > Live-demo at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/live-demo
> > http://live.osgeo.org
> > http://wiki.osgeo.org/wiki/Live_GIS_Disc
> -- Cameron Shorter
> Geospatial Solutions Manager
> Tel: +61 (0)2 8570 5050
> Mob: +61 (0)419 142 254
> Think Globally, Fix Locally
> Geospatial Solutions enhanced with Open Standards and Open Source
> http://www.lisasoft.com
More information about the Live-demo mailing list
