[Live-demo] Postgres Apps - MapFish Sahana Rasdaman PGRoutingGPSDrive
Even Rouault even.rouault at mines-paris.org
Sun Jan 22 15:28:57 EST 2012
Le dimanche 22 janvier 2012 21:16:37, maplabs at light42.com a écrit :
> Compatability for Postgres 9.1 is in the 90% + range
> The problem people run into is that since Postgres is a fundemental
> piece of any stack,
> it is some work to rebuild the stack to test with a new version...
> I would be surprised if there are any compatability problems at all for
> most all apps
> other than people hard-coding version numbers and the like
For the record, there are sometimes changes in some configuration parameters
from one PG version to another one that have lead to the following
compatibility fix (for a very marginal use case) in GDAL recently :
http://trac.osgeo.org/gdal/changeset/23651/trunk/gdal/ogr/ogrsf_frmts/pg
(improved in
http://trac.osgeo.org/gdal/changeset/23652/trunk/gdal/ogr/ogrsf_frmts/pg to
not be dependant from the PG version )
>   -Brian
> On Mon, 23 Jan 2012 06:46:57 +1100, Cameron Shorter
> <cameron.shorter at gmail.com> wrote:
> Brian,
> > Based upon Peter's request, my feeling is that we should revert back
> > to Postgres 8.4.
> > Our emphasis on OSGeo-Live is "stability over cutting edge". This is
> > because we are targeting new users who will be very quickly turned
> > off if they find a bug, and will generally not be looking to check
> > out the latest and greatest. (They can always go to a project page
> > later if they want to find latest features).
> > Anyone wish to weigh in on this topic before we make a call on which
> > posgres to use?
> > On 22/01/12 20:55, Peter Baumann wrote:
> > > Hi Brian,
> > > sorry, we have not tested rasdaman with PG 9.x yet. Given the short
> > > time remaining and current project pressure we won't be able to do
> > so > for this DVD roll-out. As in the past even minor release changes
> > in PG > have led to incompatibilities this deserves special
> > attention. We'd > kindly ask you therefore to keep 8.4 available.
> > > thanks for your understanding,
> > > Peter
> > > On 01/22/2012 06:15 AM, maplabs at light42.com wrote:
> > >> Hi All-
> > >>    I just changed the Postgres version to   9.1
> > >> install scripts for the applications listed above explicitly call out
> > >> a postgres version  (8.4)
> > >> Please check your app install scripts as we transition to the improved
> > >> 9.1 postgres base
> > >> thanks!
> > >> Brian Hamlin
> > >> GeoCal
> > >> OSGeo California Chapter
> > >> 415-717-4462 cell
> > >> _______________________________________________
> > >> Live-demo mailing list
> > >> Live-demo at lists.osgeo.org
> > >> http://lists.osgeo.org/mailman/listinfo/live-demo
> > >> http://live.osgeo.org
> > >> http://wiki.osgeo.org/wiki/Live_GIS_Disc
> > -- Cameron Shorter
> > Geospatial Solutions Manager
> > Tel: +61 (0)2 8570 5050
> > Mob: +61 (0)419 142 254
> > Think Globally, Fix Locally
> > Geospatial Solutions enhanced with Open Standards and Open Source
> > http://www.lisasoft.com
More information about the Live-demo mailing list
