[Live-demo] Postgres Apps - MapFish Sahana RasdamanPGRoutingGPSDrive
Daniel Kastl daniel at georepublic.de
Mon Jan 23 20:19:55 EST 2012
Hi Brian,
Isn't the LiveDVD still based on 11.04?
I thought it was decided that the Ubuntu version wouldn't be upgraded for
this LiveDVD. Otherwise I must have missed the news.
According to this list the official PostgreSQL version of "Natty" is 8.4:
http://packages.ubuntu.com/natty/database/
For 11.10 (Oneiric) there are indeed two version available: 8.4 and 9.1.
And for that Ubuntu release I can publish pgRouting packages for 9.1 to
Launchpad.
Daniel
On Tue, Jan 24, 2012 at 2:05 AM, <maplabs at light42.com> wrote:
> Daniel-san:
> actually, the 9.1 package is already in place..
> I simply changed the number 8.4 to 9.1 in the install script, and
> everything just worked
> as far as pgRouting packages, yes, I see your point
> someone would have to update pgRouting in that case
> postgres 8.4 is four to five years old at this point
> best regards
>   -Brian
> On Mon, 23 Jan 2012 09:58:26  0900, Daniel Kastl <daniel at georepublic.de>
> wrote:
> pgRouting is probably not going to work with 9.1, because the pgRouting
> packages on Launchpad are built for 8.4 for (X)ubuntu 11.04.It would be
> quite some extra work to just build packages for 9.1 and 11.04, which I
> would like to avoid, because these packages already exist for 11.10 (on my
> PC) and there were some patches necessary. And I don't want to revert to a
> script again to download, compile and install ;-)
> So I'm -1 to install some "non-official" PostgreSQL version on this
> LiveDVD release. It will be just a matter of six months to have 9.1 anyway
> if we will upgrade to 12.04. IMO, if 9.1 is so important we should have
> used 11.10 for this release.
> Daniel
> On Mon, Jan 23, 2012 at 5:16 AM,  <maplabs at light42.com> wrote:
> Compatability for Postgres 9.1 is in the 90%   range
> The problem people run into is that since Postgres is a fundemental piece
> of any stack,
> it is some work to rebuild the stack to test with a new version... I would
> be surprised if there are any compatability problems at all for most all
> apps
> other than people hard-coding version numbers and the like
>   -Brian
> On Mon, 23 Jan 2012 06:46:57  1100, Cameron Shorter <
> cameron.shorter at gmail.com> wrote:
> Brian,
> Based upon Peter's request, my feeling is that we should revert back to
> Postgres 8.4. Our emphasis on OSGeo-Live is "stability over cutting edge".
> This is because we are targeting new users who will be very quickly turned
> off if they find a bug, and will generally not be looking to check out the
> latest and greatest. (They can always go to a project page later if they
> want to find latest features). Anyone wish to weigh in on this topic before
> we make a call on which posgres to use?
> On 22/01/12 20:55, Peter Baumann wrote:
>> Hi Brian,
>> sorry, we have not tested rasdaman with PG 9.x yet. Given the short >
>> time remaining and current project pressure we won't be able to do so > for
>> this DVD roll-out. As in the past even minor release changes in PG > have
>> led to incompatibilities this deserves special attention. We'd > kindly ask
>> you therefore to keep 8.4 available. >
>> thanks for your understanding,
>> Peter
>> On 01/22/2012 06:15 AM, maplabs at light42.com wrote:
>>> Hi All-
>>>    I just changed the Postgres version to   9.1
>>> install scripts for the applications listed above explicitly call out a
>>> postgres version  (8.4)
>>> Please check your app install scripts as we transition to the improved
>>> 9.1 postgres base
>>> thanks!
>>> Brian Hamlin
>>> GeoCal
>>> OSGeo California Chapter
>>> 415-717-4462 cell
>>> ______________________________**_________________
>>> Live-demo mailing list
>>> Live-demo at lists.osgeo.org
>>> http://lists.osgeo.org/**mailman/listinfo/live-demo<http://lists.osgeo.org/mailman/listinfo/live-demo>
>>> http://live.osgeo.org
>>> http://wiki.osgeo.org/wiki/**Live_GIS_Disc<http://wiki.osgeo.org/wiki/Live_GIS_Disc>
> -- Cameron Shorter
> Geospatial Solutions Manager
> Tel:  61 (0)2 8570 5050
> Mob:  61 (0)419 142 254
> Think Globally, Fix Locally
> Geospatial Solutions enhanced with Open Standards and Open Source
> http://www.lisasoft.com
> Georepublic UG & Georepublic Japan
> eMail: daniel.kastl@**georepublic.de <daniel.kastl at georepublic.de>
> Web: http://georepublic.de
eMail: daniel.kastl at georepublic.de
URL: http://lists.osgeo.org/pipermail/live-demo/attachments/20120124/31878191/attachment.html
More information about the Live-demo mailing list
