[Live-demo] uDig in OSGeoLive 6.0 without JAI (and other java apps)
Angelos Tzotsos gcpp.kalxas at gmail.com
Sun Jul 22 16:39:28 PDT 2012
Cameron,
So far only Geomajas seems affected but we need more testing to be sure
about the other Java projects.
Cheers,
Angelos
On 07/23/2012 02:08 AM, Cameron Shorter wrote:
> Angelos,
> You have noted that Geomajas doesn't work with JAI moved into the
> classpath. Do you know of other java applications also effected?
> In IRC a few hours ago, Jody mentioned the version of geotools being
> used as a factor.
> I'm expanding this conversation out to a few other java project
> contacts who may have ideas to add.
> On 23/07/2012 8:50 AM, Angelos Tzotsos wrote:
>> Hi all,
>> We are having trouble making uDig work on the live disk without
>> custom jre.
>> After removing custom jre and copying JAI jars and binaries in
>> openjdk folders uDig works great but this breaks some other java
>> applications.
>> We have 2 options:
>> 1. find a way for uDig to load JAI through a custom directory (even
>> though an export LD_LIBRARY_PATH for a custom path did not work in
>> Ubuntu)
>> 2. use a pure java implementation of uDig without JAI
>> The open ticket is here: https://trac.osgeo.org/osgeo/ticket/922
>> Thoughts?
>> Regards,
>> Angelos
Angelos Tzotsos
Remote Sensing Laboratory
National Technical University of Athens
http://users.ntua.gr/tzotsos
More information about the Live-demo mailing list
