[Live-demo] 6.0 alpha4 Status
Angelos Tzotsos gcpp.kalxas at gmail.com
Thu Jun 28 02:13:01 PDT 2012
Hello Hamish,
welcome :)
comments inline:
On 06/28/2012 04:31 AM, Hamish wrote:
> Angelos wrote:
>> I just finished testing all applications on the disk
>> (6.0alpha4).
> thanks as always :)
>> Here are my findings:
>> 1. Docs are not built correctly.
> because gvsig was blocking apt,
I tried to build them again after solving manually the gvsig issue. It
still produces empty pages
>> 2. gvsig blocks the apt and applications cannot install
>> after this (this will be fixed with 1.12RC)
> dpkg: dependency problems prevent configuration of gvsig:
>   gvsig depends on openjdk-6-jre | sun-java6-jre; however:
>    Package openjdk-6-jre is not installed.
>    Package sun-java6-jre is not installed.
> dpkg: error processing gvsig (--install):
>   dependency problems - leaving unconfigured
Lets wait for 1.12RC
>> 3. 52NorthWSS still broken (and seems from an old e-mail
>> won't be fixed. I propose we drop it for 6)
> ERROR: cannot verify 52north.org's certificate, issued by `/C=IL/O=StartCom Ltd./OU=Secure Digital Certificate Signing/CN=StartCom Class 2 Primary Intermediate Server CA':
>    Unable to locally verify the issuer's authority.
> To connect to 52north.org insecurely, use `--no-check-certificate'.
> adding --no-check-certificate to the wget command lets it
> download, and presumably install.  now fixed?
I will test this...
>> 4. eoxserver can be installed but has an issue with pink
>> tiles on the demo
> sounds similar to the classic offline-mapfish issue in the
> trac'er.
>> 5. Geonetwork and Geoserver are still broken
> (no errors seen in the build log)
Trying to start from terminar gives me a JAVA_HOME not defined error
>> 6. gpsdrive is not installed but I was able to apt-get
>> install it on the vm.
> fixed in svn, I had the version number wrong. FWIW the
> apt-get'able version is not useful in this particular case.
thanks for the fix
>> 7. mapfish now is installed but does not start
> requires geoserver?
I am not sure this is the problem here, since it existed in alpha2
(Geoserver worked)
>> 8. mapnik still has some demo issues
> ditto?
>> 9. launcher is missing for maptiler
>> 10. gosmore freezes and josm does not start
> any error messages to follow if you start them from the command
> line? see quickstart for building the gosmore cache the first
> time you start it. build log looks ok.
>> 11. ossim is not installed
> the deb needs to be rebuilt for Ubuntu 12.04 or UbuntuGIS,
> TODO: libgeotiff2 is current, libgeotiff1.2 called
> Reading package lists...
> Building dependency tree...
> Reading state information...
> E: Unable to locate package libgeotiff1.2
> E: Couldn't find any package by regex 'libgeotiff1.2'
> E: Unable to locate package libgdal1-1.8.0
> E: Couldn't find any package by regex 'libgdal1-1.8.0'
> E: Unable to locate package libopenscenegraph65
> E: Unable to locate package libgdal1-1.8.0-grass
> E: Couldn't find any package by regex 'libgdal1-1.8.0-grass'
> ERROR: Package install failed! Aborting.
>> 12. rasdaman is now installed but with some demo issues
>> (getting some exceptions in WMS capabilities)
>> 13. tinyows not installed
> seems it is not present in UbuntuGIS's ppa for 12.04?
> E: Unable to locate package tinyows
>> 14. udig still has custom jre
>> 15. zygrib has no launcher (but works)
> custom repo for the latest version is missing packages for
> Precise, so it falls back onto the Ubuntu 12.04 official version,
> which is rather poorly packaged. (I'm rather surprised it made
> it past the Debian ftpmasters' scrutiny to be honest)
> I've been hoping that upsteam would post their new pkg, but
> if not I'll go in and clean up the launcher etc by hand.
>> 16. zoo-project demo is broken (based on geoserver)
> also, the error check grep at the end of the build log gets
> itself into a bit of a recursive loop.
> thanks,
> Hamish
>> Angelos Tzotsos wrote:
>>> alpha4 is now available:
>>> http://aiolos.survey.ntua.gr/gisvm/6.0/osgeo-live-6.0alpha4-log.tar.gz
>>> http://aiolos.survey.ntua.gr/gisvm/6.0/osgeo-live-vm-6.0alpha4.7z
>>> http://aiolos.survey.ntua.gr/gisvm/6.0/osgeo-live-mini-6.0alpha4.iso
Angelos Tzotsos
Remote Sensing Laboratory
National Technical University of Athens
http://users.ntua.gr/tzotsos
More information about the Live-demo mailing list
