[Live-demo] JTS on OSGeo-Live
Cameron Shorter
cameron.shorter at gmail.com
Tue Oct 23 18:17:33 PDT 2012
I hope no one CCed minds if we take this thread back to the live email
list, so we can capture the technical discussion.
On 24/10/2012 12:13 PM, Jody Garnett wrote:
> I have done the overview / fact sheet; waiting for a review on the
> live-demo email list. For my purposes (explaining what GIS is as part
> of an "OSGeo-Live" talk) having the fact sheet is enough.
> However the JTS desktop tool would be an *amazing* addition to
> OSGeo-Live for use in an educational context, the ability to take a
> class enter in a couple geometries and have them try out the
> operations would be far better then explaining this in PostGIS and
> pgAdmin.
> install steps:
> 1)
> Download http://sourceforge.net/projects/jts-topo-suite/files/jts/1.12/jts-1.12.zip/download
> 2) Unzip
> 3) Copy in the following build.xml
> <project name="JTS" basedir="." default="run">
> <property name="lib" value="lib"/>
> <property name="main-class"
> value="com.vividsolutions.jtstest.testbuilder.JTSTestBuilder"/>
> <path id="classpath">
> <fileset dir="${lib}" includes="**/*.jar"/>
> </path>
> <target name="run">
> <java fork="true" classname="${main-class}">
> <classpath>
> <path refid="classpath"/>
> <path location="${jar.dir}/${ant.project.name}.jar"/>
> </classpath>
> </java>
> </target>
> </project>
> 4) Type the following on the command line:
> ant
> Jody Garnett
> On Wednesday, 24 October 2012 at 10:57 AM, Stefan Steiniger wrote:
>> Ah ok, I had the same question as Landon w.r.t. an installer.
>> So the question remaining is Landons other question:
>> What is the schedule?
>> I could imagine to do the fact-sheet for JTS (though - its for JTS not
>> the testbuilder - which I agree, is a nifty tool; at least for teaching)
>> and maybe a short intro. But I think Landon did do the latter already?
>> Installer... depends... maybe we can ask Ede from OJ for advise (but he
>> also had a full plate ;)
>> cheers,
>> stefan
>> Am 23.10.12 17:16, schrieb Martin Davis:
>>> Right now you have to use a BAT/SH file to run them. I haven't done
>>> the work to make them JAR-launchable.
>>> On Tue, Oct 23, 2012 at 12:58 PM, Landon Blake <lblake at ksninc.com
>>> <mailto:lblake at ksninc.com>> wrote:
>>>> Roger. Are those typically executed by double clicking on a JAR or by
>>>> using a BAT file?
>>>> Landon Blake, P.L.S.
>>>> Project Surveyor
>>>> Kjeldsen, Sinnock & Neudeck, Inc.
>>>> 711 N. Pershing Avenue, Stockton CA 95203
>>>> 209 946-0268 | fax: 209 946-0296
>>>> lblake at ksninc.com | http://www.ksninc.com
>>>> Warning:
>>>> Information provided via electronic media is not guaranteed against
>>>> defects including translation and transmission errors. If the
>>>> reader is not the intended recipient, you are hereby notified that
>>>> any dissemination, distribution or copying of this communication is
>>>> strictly prohibited. If you have received this information in
>>>> error, please notify the sender immediately.
>>>> -----Original Message-----
>>>> From: Martin Davis [mailto:mtnclimb at gmail.com]
>>>> Sent: Tuesday, October 23, 2012 12:58 PM
>>>> To: Landon Blake
>>>> Cc: Cameron Shorter; Jody; Stefan Steiniger
>>>> Subject: Re: [Live-demo] JTS on OSGeo-Live
>>>> JTS comes with a couple of user-level tools - the TestBuilder and the
>>>> TestRunner. The TestRunner is a bit esoteric, but the TestBuilder I
>>>> think would make a fine tool to be installed on the Quickstart.
>>>> M
>>>> On Tue, Oct 23, 2012 at 12:33 PM, Landon Blake <lblake at ksninc.com
>>>> wrote:
>>>>> JTS is an important library, so I will make time to assist.
>>>>> I know a bit about the Quickstart. What do you mean by "installer"?
>>>>> JTS is really a library and not an application, so I'm not sure what
>>>>> we would need for an installer.
>>>>> Let me know more about that and I will get started. What is our
>>>>> timeline for this little project?
>>>>> Landon
>>>>> Project Surveyor
>>>>> Warning:
>>>> defects including translation and transmission errors. If the reader is
>>>> not the intended recipient, you are hereby notified that any
>>>> strictly
>>>> prohibited. If you have received this information in error, please
>>>>> From: Cameron Shorter [mailto:cameron.shorter at gmail.com]
>>>>> Sent: Tuesday, October 23, 2012 12:24 PM
>>>>> To: Martin Davis
>>>>> Cc: Jody; Landon Blake; Stefan Steiniger
>>>>> Landon, Stefan,
>>>>> I'm wondering if either (or both) of you would be able to help get JTS
>>>>> onto OSGeo-Live.
>>>>> Jody has started, by writing a Project Overview.
>>>>> We still need an installer and Quickstart.
>>>>> On Monday, 22 October 2012 at 11:59, Martin Davis wrote:
>>>>> Guys,
>>>>> I'm happy to have JTS included on OSGeo Live, but the sad fact is I
>>>>> just don't have any time right now to prepare the necessary artifacts
>>>> myself.
>>>>> If someone else wants to take this on I'm happy to advise, but
>>>>> otherwise JTS will have to continue to languish in obscurity...
>>>>> Martin
>>>>> On 23/10/12 10:48, Martin Davis wrote:
>>>>>> On Mon, Oct 22, 2012 at 4:30 PM, Cameron Shorter
>>>>>> <cameron.shorter at gmail.com <mailto:cameron.shorter at gmail.com>> wrote:
>>>>>>> Martin, if we find someone to write the docs and installer, are you
>>>>>>> prepared to review it?
>>>>>>> Can you suggest a likely candidate who might be willing to help out?
>>>>>> Yes, certainly, happy to review it.
>>>>>> Possibly Landon (Sunburned Surveyor)? He has been interested in JTS
>>>>>> documentation in the past. Another possibility is Stefan Steineger.
>>>>> Cameron Shorter
>>>>> Geospatial Solutions Manager
>>>>> Tel: +61 (0)2 8570 5050
>>>>> Mob: +61 (0)419 142 254
>>>>> Think Globally, Fix Locally
>>>>> Geospatial Solutions enhanced with Open Standards and Open Source
>>>>> http://www.lisasoft.com
Cameron Shorter
URL: <http://lists.osgeo.org/pipermail/live-demo/attachments/20121024/50c75a99/attachment-0001.html>
More information about the Live-demo
