[Live-demo] JTS on OSGeo-Live
Cameron Shorter
cameron.shorter at gmail.com
Wed Oct 24 12:55:09 PDT 2012
On 25/10/2012 12:20 AM, Stefan Steiniger wrote:
> Hi,
> thanks Jody!
> Having now this Ant build and a FAQ
> I am confused and have two questions to the liveDVD builders/Cameron:
> (i) what ToDo's are open? (proof reading?)
We need someone to officially apply to join the OSGeo-Live project, by
sending an email addressing our standard questions, as per:
http://wiki.osgeo.org/wiki/Live_GIS_Disc_Apply
We need someone to write an install_jst.sh script as per:
http://wiki.osgeo.org/wiki/Live_GIS_Add_Project#Install_Script
The Application Overview needs to cover JTS's desktop application.
Ideally, someone will find or create a logo for JTS
Someone needs to write a Quickstart as per:
http://wiki.osgeo.org/wiki/Live_GIS_Add_Project#Application_Quick_Start
> (ii) what is the timelime?
Schedule for the next OSGeo-Live release is currently being discussed.
If we follow the same schedule as last year, it will be something like:
feature freeze ~ early January 2013
all apps delivered to UAT ~ early February 2013
final ISO ~ early March 2013
> cheers,
> stefan
> Am 23.10.12 23:21, schrieb Brian Hamlin:
>> I "discovered" JTS Test Builder in 2007 (when I started in Geo).. it
>> would be a fine addition IMO
>> I still fire it up now and then.. Mac and Linux.. though not as
>> neatly as Jody
>> shown below.. and without ant..
>> cd $src_dir
>> java -classpath "jdom.jar:xerces.jar:JTS_Test.jar:jts-1.8.jar"
>> com.vividsolutions.jtstest.testbuilder.JTSTestBuilder
>> Brian Hamlin
>> OSGeo California Chapter
>> 415-717-4462 cell
>> On Oct 23, 2012, at 6:17 PM, Cameron Shorter wrote:
>>> I hope no one CCed minds if we take this thread back to the live email
>>> list, so we can capture the technical discussion.
>>> On 24/10/2012 12:13 PM, Jody Garnett wrote:
>>>> I have done the overview / fact sheet; waiting for a review on the
>>>> live-demo email list. For my purposes (explaining what GIS is as part
>>>> of an "OSGeo-Live" talk) having the fact sheet is enough.
>>>> However the JTS desktop tool would be an *amazing* addition to
>>>> OSGeo-Live for use in an educational context, the ability to take a
>>>> class enter in a couple geometries and have them try out the
>>>> operations would be far better then explaining this in PostGIS and
>>>> pgAdmin.
>>>> install steps:
>>>> 1) Download
>>>> http://sourceforge.net/projects/jts-topo-suite/files/jts/1.12/jts-1.12.zip/download
>>>> 2) Unzip
>>>> 3) Copy in the following build.xml
>>>> <project name="JTS" basedir="." default="run">
>>>> <property name="lib" value="lib"/>
>>>> <property name="main-class"
>>>> value="com.vividsolutions.jtstest.testbuilder.JTSTestBuilder"/>
>>>> <path id="classpath">
>>>> <fileset dir="${lib}" includes="**/*.jar"/>
>>>> </path>
>>>> <target name="run">
>>>> <java fork="true" classname="${main-class}">
>>>> <classpath>
>>>> <path refid="classpath"/>
>>>> <path location="${jar.dir}/${ant.project.name}.jar"/>
>>>> </classpath>
>>>> </java>
>>>> </target>
>>>> </project>
>>>> 4) Type the following on the command line:
>>>> ant
>>>> Jody Garnett
>>>> On Wednesday, 24 October 2012 at 10:57 AM, Stefan Steiniger wrote:
>>>>> Ah ok, I had the same question as Landon w.r.t. an installer.
>>>>> So the question remaining is Landons other question:
>>>>> What is the schedule?
>>>>> I could imagine to do the fact-sheet for JTS (though - its for JTS
>>>>> not
>>>>> the testbuilder - which I agree, is a nifty tool; at least for
>>>>> teaching)
>>>>> and maybe a short intro. But I think Landon did do the latter
>>>>> already?
>>>>> Installer... depends... maybe we can ask Ede from OJ for advise
>>>>> (but he
>>>>> also had a full plate ;)
>>>>> cheers,
>>>>> stefan
>>>>> Am 23.10.12 17:16, schrieb Martin Davis:
>>>>>> Right now you have to use a BAT/SH file to run them. I haven't done
>>>>>> the work to make them JAR-launchable.
>>>>>> On Tue, Oct 23, 2012 at 12:58 PM, Landon Blake <lblake at ksninc.com>
>>>>>> wrote:
>>>>>>> Roger. Are those typically executed by double clicking on a JAR
>>>>>>> or by
>>>>>>> using a BAT file?
>>>>>>> Landon Blake, P.L.S.
>>>>>>> Project Surveyor
>>>>>>> Kjeldsen, Sinnock & Neudeck, Inc.
>>>>>>> 711 N. Pershing Avenue, Stockton CA 95203
>>>>>>> 209 946-0268 | fax: 209 946-0296
>>>>>>> lblake at ksninc.com | http://www.ksninc.com
>>>>>>> Warning:
>>>>>>> Information provided via electronic media is not guaranteed
>>>>>>> against defects including translation and transmission errors. If
>>>>>>> the reader is not the intended recipient, you are hereby notified
>>>>>>> that any dissemination, distribution or copying of this
>>>>>>> communication is strictly prohibited. If you have received this
>>>>>>> information in error, please notify the sender immediately.
>>>>>>> -----Original Message-----
>>>>>>> From: Martin Davis [mailto:mtnclimb at gmail.com]
>>>>>>> Sent: Tuesday, October 23, 2012 12:58 PM
>>>>>>> To: Landon Blake
>>>>>>> Cc: Cameron Shorter; Jody; Stefan Steiniger
>>>>>>> Subject: Re: [Live-demo] JTS on OSGeo-Live
>>>>>>> JTS comes with a couple of user-level tools - the TestBuilder
>>>>>>> and the
>>>>>>> TestRunner. The TestRunner is a bit esoteric, but the TestBuilder I
>>>>>>> think would make a fine tool to be installed on the Quickstart.
>>>>>>> M
>>>>>>> On Tue, Oct 23, 2012 at 12:33 PM, Landon Blake <lblake at ksninc.com>
>>>>>>> wrote:
>>>>>>>> JTS is an important library, so I will make time to assist.
>>>>>>>> I know a bit about the Quickstart. What do you mean by
>>>>>>>> "installer"?
>>>>>>>> JTS is really a library and not an application, so I'm not sure
>>>>>>>> what
>>>>>>>> we would need for an installer.
>>>>>>>> Let me know more about that and I will get started. What is our
>>>>>>>> timeline for this little project?
>>>>>>>> Landon
>>>>>>>> Project Surveyor
>>>>>>>> Warning:
>>>>>>>> against
>>>>>>> defects including translation and transmission errors. If the
>>>>>>> reader is
>>>>>>> not the intended recipient, you are hereby notified that any
>>>>>>> dissemination, distribution or copying of this communication is
>>>>>>> strictly
>>>>>>> prohibited. If you have received this information in error, please
>>>>>>>> From: Cameron Shorter [mailto:cameron.shorter at gmail.com]
>>>>>>>> Sent: Tuesday, October 23, 2012 12:24 PM
>>>>>>>> To: Martin Davis
>>>>>>>> Cc: Jody; Landon Blake; Stefan Steiniger
>>>>>>>> Landon, Stefan,
>>>>>>>> I'm wondering if either (or both) of you would be able to help
>>>>>>>> get JTS
>>>>>>>> onto OSGeo-Live.
>>>>>>>> Jody has started, by writing a Project Overview.
>>>>>>>> We still need an installer and Quickstart.
>>>>>>>> On Monday, 22 October 2012 at 11:59, Martin Davis wrote:
>>>>>>>> Guys,
>>>>>>>> I'm happy to have JTS included on OSGeo Live, but the sad fact
>>>>>>>> is I
>>>>>>>> just don't have any time right now to prepare the necessary
>>>>>>>> artifacts
>>>>>>> myself.
>>>>>>>> If someone else wants to take this on I'm happy to advise, but
>>>>>>>> otherwise JTS will have to continue to languish in obscurity...
>>>>>>>> Martin
>>>>>>>> On 23/10/12 10:48, Martin Davis wrote:
>>>>>>>>> On Mon, Oct 22, 2012 at 4:30 PM, Cameron Shorter
>>>>>>>>> <cameron.shorter at gmail.com> wrote:
>>>>>>>>>> Martin, if we find someone to write the docs and installer, are
>>>>>>>>>> you
>>>>>>>>>> prepared to review it?
>>>>>>>>>> Can you suggest a likely candidate who might be willing to help
>>>>>>>>>> out?
>>>>>>>>> Yes, certainly, happy to review it.
>>>>>>>>> Possibly Landon (Sunburned Surveyor)? He has been interested
>>>>>>>>> in JTS
>>>>>>>>> documentation in the past. Another possibility is Stefan
>>>>>>>>> Steineger.
>>>>>>>> Cameron Shorter
>>>>>>>> Geospatial Solutions Manager
>>>>>>>> Tel: +61 (0)2 8570 5050
>>>>>>>> Mob: +61 (0)419 142 254
>>>>>>>> Think Globally, Fix Locally
>>>>>>>> Geospatial Solutions enhanced with Open Standards and Open Source
>>>>>>>> http://www.lisasoft.com
>>> -- Cameron Shorter Geospatial Solutions Manager Tel: +61 (0)2 8570
>>> 5050 Mob: +61 (0)419 142 254 Think Globally, Fix Locally Geospatial
>>> Live-demo mailing list
>>> Live-demo at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/live-demo
>>> http://live.osgeo.org
Cameron Shorter
More information about the Live-demo
