[Live-demo] [OSGeo-Standards] FYI: New OGC Standards Activity: Candidate GeoPackage Standard
Cameron Shorter cameron.shorter at gmail.com
Thu Oct 25 14:37:13 PDT 2012
Thanks Frank, I think I've now also found the doc you are probably reading:
https://portal.opengeospatial.org/files/50347
This includes the following description:
/Mobile device users who require map/geospatial application services and
operate in disconnected or limited network connectivity environments are
challenged by not having open, available geospatial data to support
these applications. Further challenging mobile device users are the
limited storage available and the likelihood that each map/geospatial
application will require its own potentially proprietary geospatial data
store. These separate application-specific data stores may contain the
same geospatial data, wasting the limited storage available, and
requiring custom applications for data translation, replication, and
synchronization to enable different map/geospatial applications to share
the same world view. In addition, many existing geospatial data stores
are platform-specific, which means that users with different platforms
must translate data to share it.//
//An open, standards-based, application-independent,
platform-independent, self-describing, GeoPackage (GPKG) data container,
API and manifest are needed to overcome these challenges and to
effectively support multiple map/geospatial applications such as fixed
product distribution, local data collection, and geospatially enabled
analytics. This standard is intended to facilitate widespread adoption
and use of GeoPackages as standard containers for "MyGeoData" by both
COTS and open-source software applications on enterprise production
platforms as well as mobile hand-held devices, given that mobile hand
held devices do not yet have the processing power or battery life to
effectively tackle difficult geospatial product production and analysis
tasks. An application that accesses a GPKG will make use of the GPKG
capabilities it requires; few if any such applications will make use of
all GPKG capabilities.//
//A future GeoPackage Web Service specification and modifications to
existing OGC Web Service (OWS) specifications to use GeoPackages as
exchange formats will allow OWS to support provisioning of GeoPackages
throughout an enterprise or information community./
On 26/10/2012 8:28 AM, Frank Warmerdam wrote:
> Cameron,
> For what it's worth, from a very brief review it seems like
> GeoPackages are data packages containing primarily SQLite/Spatialite
> databases for vectors and MBTiles format for raster/map tiles.  I
> don't initially see it having any relationship to software packaging.
> I'm going to poke around a bit and try to establish if any work in
> GDAL would help with compatability.  It might be interesting to
> package some of the OSGeo Live dataset(s) as GeoPackages at some point.
> (I must stress my vague understanding is based on a very cursory
> review of OGC docs, email, etc)
> Best regards,
> Frank
> On Thu, Oct 25, 2012 at 2:19 PM, Cameron Shorter
> <cameron.shorter at gmail.com <mailto:cameron.shorter at gmail.com>> wrote:
>     Carl,
>     It is possible that contributors to the OSGeo-Live project [1]
>     might have something of value to contribute toward this GeoPackage
>     standard.
>     OSGeo-Live packages provides installer scripts for 50+ geospatial
>     open source applications,  and data sources, such that they can be
>     installed on linux distribution, and run offline.
>     It is possible that this OSGeo-Live build process could be
>     tailored for the specific requirements of the GeoPackaging community.
>     [1] http://live.osgeo.org
>     A description of the build process:
>     http://cameronshorter.blogspot.com.au/2011/06/memoirs-of-cat-herder-coordinating.html
>     On 26/10/2012 5:08 AM, Carl Reed wrote:
>         The following standards work is based on OGC test bed
>         activities and related projects for packaging geospatial
>         content for use in a mobile environment in which disconnected
>         devices are the norm, such as in emergency response after a
>         natural disaster.
>         Today the OGC® announced the formation of a new OGC® Technical
>         Committee Standards Working Group (SWG) to advance the
>         candidate OGC GeoPackage Standard.
>         http://spatialnews.geocomm.com/dailynews/2012/oct/25/news3.html
>         OGC members are proposing an open, non-proprietary,
>         platform-independent GeoPackage container for distribution and
>         direct use of all kinds of geospatial data. The GeoPackage
>         container and related API will increase the cross-platform
>         interoperability of geospatial applications and web services
>         in the mobile world. Standard APIs for access and management
>         of GeoPackage data will provide consistent query and update
>         results across such applications and services.
>         Regards
>         Carl Reed, PhD
>         CTO and Executive Director Standards Program
>         Open Geospatial Consortium
>         www.opengeospatial.org <http://www.opengeospatial.org>
>         The OGC: Making Location Count!
>         This communication, including attachments, is for the
>         exclusive use of addressee and may contain proprietary,
>         confidential or privileged information. If you are not the
>         intended recipient, any use, copying, disclosure,
>         dissemination or distribution is strictly prohibited. If you
>         are not the intended recipient, please notify the sender
>         immediately by return email and delete this communication and
>         destroy all copies.
>         "The important thing is not to stop questioning." -- Albert
>         Einstein
>         "Security is mostly a superstition. It does not exist in
>         nature. Life is either a daring adventure or nothing." --
>         Helen Keller
>         _______________________________________________
>         Standards mailing list
>         Standards at lists.osgeo.org <mailto:Standards at lists.osgeo.org>
>         http://lists.osgeo.org/mailman/listinfo/standards
>     Cameron Shorter
>     Geospatial Solutions Manager
>     Tel: +61 (0)2 8570 5050 <tel:%2B61%20%280%292%208570%205050>
>     Mob: +61 (0)419 142 254 <tel:%2B61%20%280%29419%20142%20254>
>     Think Globally, Fix Locally
>     Geospatial Solutions enhanced with Open Standards and Open Source
>     http://www.lisasoft.com
>     Live-demo mailing list
>     Live-demo at lists.osgeo.org <mailto:Live-demo at lists.osgeo.org>
>     http://lists.osgeo.org/mailman/listinfo/live-demo
>     http://wiki.osgeo.org/wiki/Live_GIS_Disc
> I set the clouds in motion - turn up   | Frank Warmerdam,
> warmerdam at pobox.com <mailto:warmerdam at pobox.com>
> light and sound - activate the windows | http://pobox.com/~warmerdam
> <http://pobox.com/%7Ewarmerdam>
> and watch the world go round - Rush    | Geospatial Software Developer
Cameron Shorter
URL: <http://lists.osgeo.org/pipermail/live-demo/attachments/20121026/83b1ca97/attachment.html>
More information about the Live-demo mailing list
