[Live-demo] Fwd: Packaging and project re-organization
Angelos Tzotsos gcpp.kalxas at gmail.com
Thu Dec 26 10:21:30 PST 2013
Thanks Johan,
There is a packaging column in our package spreadsheet here:
https://docs.google.com/spreadsheet/ccc?key=0Al9zh8DjmU_RdGIzd0VLLTBpQVJuNVlHMlBWSDhKLXc&usp=drive_web#gid=13
and and overview here:
http://lists.osgeo.org/pipermail/live-demo/2013-December/008540.html
+1 on the IRC sessions. We can also join Vienna code sprint in March
with a debian packaging session.
Best,
Angelos
On 12/26/2013 08:08 PM, Johan Van de Wauw wrote:
> Angelos,
> I'm very much in favor. Well I actually made similar proposal before.
> Do we have an overview of which packages are not yet packaged in .deb files?
> Perhaps we can setup some IRC coaching sessions for people to get
> started with packaging.
> Johan
> On Mon, Dec 23, 2013 at 3:04 PM, Angelos Tzotsos <gcpp.kalxas at gmail.com> wrote:
>> On 12/10/2013 10:52 PM, Angelos Tzotsos wrote:
>> My proposal here is to split the project (since it grew too big):
>> - OSGeoLive ppa (UbuntuGIS or perhaps other)
>> - OSGeoLive apt repository (for packages not fitting under the Launchpad
>> rules, eg. Java binary packages)
>> - OSGeoLive docs and translations (should be maintained separately and
>> create a deb file periodically e.g. for every new commit)
>> - OSGeoLive data (also should be packaged in a deb file)
>> - OSGeoLive build scripts (for anything not in a deb file, e.g. the actual
>> build files)
>> This would also simplify things:
>> All projects must provide deb packages, else they are not included in the
>> 8.0 release. So 7.9 will be a transition release...
>> Hi all,
>> Based on the previous proposal I would to discuss the potential solutions on
>> how to create Debian packages targeting the 8.0 release:
>> My suggestion here is to create a Launchpad account for OSGeoLive, which we
>> will use to "freeze" UbuntuGIS-Unstable when we are preparing a release.
>> This means that this OSGeoLive ppa will not be used for packaging, just for
>> release purposes, to avoid last minute changes in UbuntuGIS-Unstable.
>> Alternatively we could use UbuntuGIS-Stable and try to keep the packages we
>> need there, but this would require the OSGeoLive team to have a certain
>> level of control to that ppa which I am not sure it is proper.
>> The second step is to make sure we have a place to host deb files that are
>> not acceptable under the Launchpad rules. A simple solution would be to
>> create an apt-repository to the OSGeo infrastructure. We just need a folder
>> under apache and ssh access so that we can periodically upload deb files and
>> re-calculate the index:
>> http://www.hiddentao.com/archives/2011/06/27/setting-up-a-simple-ubuntu-apt-repository/
>> The third and "difficult" part is the deb packaging itself. Here we have
>> several possible paths:
>> 1. Use all the standard tools in Debian packaging and create/update packages
>> on UbuntuGIS ppa.
>> A VERY simple example to create a deb package is shown here:
>> http://ubuntuforums.org/showthread.php?t=910717
>> but usually more complex things are required so the complete guides can be
>> found here:
>> https://wiki.debian.org/IntroDebianPackaging
>> http://www.debian.org/doc/manuals/maint-guide/
>> http://packaging.ubuntu.com/html/
>> 2. Use helper programs to produce deb packages.
>> Recently I used this excellent tool for packaging/deployment:
>> https://github.com/jordansissel/fpm
>> https://github.com/jordansissel/fpm/wiki
>> http://goo.gl/sWs3Z
>> This actually can save us lots of trouble, especially for building things
>> that cannot easily be moved to Launchpad.
>> Small example to create a GeoServer package:
>> $ cd /tmp
>> $ wget
>> http://sourceforge.net/projects/geoserver/files/GeoServer/2.4.3/geoserver-2.4.3-war.zip
>> $ unzip geoserver-2.4.3-war.zip
>> $ mkdir -p /tmp/geoserver-root/var/lib/tomcat6/webapps
>> $ mv geoserver.war /tmp/geoserver-root/var/lib/tomcat6/webapps/
>> $ fpm -s dir -t deb -v 2.4.3 -n geoserver -a all -d tomcat6 -C
>> /tmp/geoserver-root .
>> and we have a geoserver_2.4.3_all.deb file ready for us. This also declares
>> tomcat6 as a dependency and will just deploy the war file in the correct
>> tomcat folder.
>> Then we upload this to our OSGeo apt repository (since we cannot upload Java
>> binaries to Launchpad) and we simple change the install_geoserver.sh to
>> apt-get install geoserver. OK, it is a bit more complicated than this, but
>> you get the picture :)
>> FPM also supports translation of Ruby gems and Python packages into any
>> other format... so it is easy to create deb packages from pypi...
>> This can also be combined with Ansible and Vagrant to automate every step of
>> the build process.
>> http://www.ansibleworks.com/docs/guide_vagrant.html
>> http://www.ansibleworks.com/docs/playbooks.html
>> Thoughts?
>> Cheers,
>> Angelos
>> Angelos Tzotsos
>> Remote Sensing Laboratory
>> National Technical University of Athens
>> http://users.ntua.gr/tzotsos
>> Live-demo mailing list
>> Live-demo at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/live-demo
>> http://live.osgeo.org
>> http://wiki.osgeo.org/wiki/Live_GIS_Disc
Angelos Tzotsos
More information about the Live-demo mailing list
