[Live-demo] [OSGeo] #1101: osgeolive - OSGeo Software Help - link broken
OSGeo
trac_osgeo at osgeo.org
Mon Feb 11 11:49:32 PST 2013
Reporter: epifanio | Owner: live-demo@…
Type: defect | Status: new
Priority: blocker | Milestone: OSGeoLive6.5
Component: LiveDVD | Keywords: docs, sphinx, i18n
Changes (by hamish):
* keywords: => docs, sphinx, i18n
Comment:
Sphinx died in zh/quickstart/mapwindow.
It died the same for me on the adhoc build server when I had LANG=C, but
not when I had LANG=en_US.UTF-8 with that it was ok.
reading sources... [ 97%] zh/quickstart/mapnik_quickstart
reading sources... [ 97%] zh/quickstart/mapproxy_quickstart
reading sources... [ 97%] zh/quickstart/mapserver_quickstart
reading sources... [ 97%] zh/quickstart/maptiler_quickstart
reading sources... [ 97%] zh/quickstart/mapwindow_quickstart
Exception occurred:
File "/usr/lib/python2.7/dist-packages/sphinx/cmdline.py", line 189, in
main
app.build(force_all, filenames)
File "/usr/lib/python2.7/dist-packages/sphinx/application.py", line 204,
in build
self.builder.build_update()
File "/usr/lib/python2.7/dist-packages/sphinx/builders/__init__.py",
line 196, in build_update
'out of date' % len(to_build))
line 216, in build
purple, length):
line 120, in status_iterator
for item in iterable:
File "/usr/lib/python2.7/dist-packages/sphinx/environment.py", line 613,
in update_generator
self.read_doc(docname, app=app)
File "/usr/lib/python2.7/dist-packages/sphinx/environment.py", line 769,
in read_doc
self.process_images(docname, doctree)
File "/usr/lib/python2.7/dist-packages/sphinx/environment.py", line 948,
in process_images
if not os.access(path.join(self.srcdir, imgpath), os.R_OK):
UnicodeEncodeError: 'ascii' codec can't encode characters in position
102-134: ordinal not in range(128)
The full traceback has been saved in /tmp/sphinx-err-2HfO3Q.log, if you
want to report the issue to the developers.
Please also report this if it was a user error, so that a better error
message can be provided next time.
Either send bugs to the mailing list at <http://groups.google.com/group
/sphinx-dev/>,
or report them in the tracker at
<http://bitbucket.org/birkenfeld/sphinx/issues/>. Thanks!
make: *** [sphinxbuild] Error 1
mv: cannot stat `*': No such file or directory
rm -rf _build
rm -f licenses.csv
# remove symbolic linked files
rm -f `find ./*/ -type l -print`
./install_main_docs.sh: 81: cd: can't cd to /var/www/_images/
install_main_docs.sh: Double-check that the Firefox home page is now set
to file:///var/www/index.html
find: `/home/user/.mozilla/firefox/': No such file or directory
the quickstart after mapwindow is marble_quickstart.rst. could be that one
too.
Hamish
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/1101#comment:1>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo
