[Live-demo] Status of full osgeolive 6.5 - Completed
Alex Mandel tech_dev at wildintellect.com
Sat Feb 23 21:36:06 PST 2013
I've burned and booted a DVD, booted in a VM. Confirmed the fix to the
doc pages links to the Win/Mac directories. I'm ready to call the full
iso complete and will upload to sourceforge once everyone has a chance
to look at the build log (14), test or ponder and state their opinion.
Hamish had some tweaks he wanted to see applied to the VM and then that
should be ready for upload too.
Thanks,
Alex
On 02/23/2013 04:03 PM, Alex Mandel wrote:
> I believe it is corrected now (I checked in a VM) and uploaded. It still
> needs a burn test and second person to verify the fix is correct.
> Thanks,
> Alex
> On 02/23/2013 01:25 PM, Alex Mandel wrote:
>> Chatted with Angelos, we think we know the issue. He had put the
>> installers into the squash instead of next to it, which grew the squash
>> above 4GB which isn't normally supported on a normal ISO cd without udf
>> specifically turned on.
>> We'll fix the script and try again.
>> Thanks,
>> Alex
>> On 02/23/2013 01:16 PM, Alex Mandel wrote:
>>> Something isn't right, after I worked around the hard coded paths that
>>> didn't match my system it gave and error about size at the last step.
>>> It sounds like it might be overridable with a flag to the geniso but
>>> that might also result in file that's too big to burn.
>>> "File ./casper/filesystem.squashfs is larger than 4GiB-1.
>>> -allow-limited-size was not specified. There is no way do represent this
>>> file size. Aborting."
>>> The script cleaned itself up so I can't inspect the "bad" squashfs size.
>>> Log is up
>>> http://osprey.ucdavis.edu/downloads/osgeo/gisvm/6.5nightly/build_debug_full-12.log
>>> Thanks,
>>> Alex
>>> On 02/23/2013 05:16 AM, Angelos Tzotsos wrote:
>>>> Hi all,
>>>> I just completed the fix for #1093 in r10035
>>>> Hamish can you please review the script?
>>>> Alex can you please try it? (heads up: you will have to change the
>>>> mirror to point to your copy of mini iso)
>>>> Hope this solves this and we can produce the final full iso too.
>>>> Cheers,
>>>> Angelos
>>>> On 02/22/2013 10:39 PM, Hamish wrote:
>>>>> Cameron wrote:
>>>>>> https://trac.osgeo.org/osgeo/ticket/1093
>>>>>> The current situation is
>>>>>> that in the full iso, the index.html file in
>>>>>> the Win/Mac? Downloads directory is not
>>>>>> being removed as it should.
>>>>> right, and replaced with symlinks back to the dirs in /cdrom.
>>>>> besides the new index.html files the dirs need to be removed
>>>>> as well.
>>>>>>     Options to try:
>>>>>> 1. At the start of the bin/build_full_iso.sh, remove the
>>>>>> doc/WindowsInstallers/index.rst
>>>>>> and doc/MacInstallers/index.rst source files.
>>>>> we tried that, it didn't work. those files are frozen up
>>>>> inside the squashfs filesystem on the iso.
>>>>>> 2. Retrospectively unpack the iso image, remove the index.html
>>>>>> file, then repack the image.
>>>>> right, & that's exactly what Angelos is planning on doing.
>>>>> for 7.0 I've modified rc.local to make this choice at boot time,
>>>>> based on the availablilty of the installers or not. Since the
>>>>> mini iso is pretty much ready at this point it's too late for
>>>>> this round so we'll do some open air brain surgery on the full
>>>>> iso to fix it by hand this time. Not ideal, but we're pretty
>>>>> familiar with the method by now.
>>>>> regards,
>>>>> Hamish
>>> Live-demo mailing list
>>> Live-demo at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/live-demo
>>> http://live.osgeo.org
>>> http://wiki.osgeo.org/wiki/Live_GIS_Disc
More information about the Live-demo mailing list
