[Live-demo] One version of geoserver on OSGeo-Live
Cameron Shorter cameron.shorter at gmail.com
Mon Jun 10 16:24:49 PDT 2013
Ian Turton has recommended 2.3.3 (with 2.3.4 possible) for GeoServer.
Ian,
As there are other projects dependant upon GeoServer, I'll revise my
previous advice to you, and suggest that we should try and lock in a
stable version of GeoServer earlier than other projects so the other
projects have time to test their applications. Ie, I'd suspect GeoServer
2.3.3 would probably be preferable.
On 11/06/2013 12:37 AM, Angelos Tzotsos wrote:
> Hi Patric,
> I have already updated GeoServer to 2.3.2 in nightly builds.
> http://aiolos.survey.ntua.gr/gisvm/dev/osgeo-live-debug-build10154-i386.iso
> http://aiolos.survey.ntua.gr/gisvm/dev/osgeo-live-debug-build10154-i386-log.tar.gz
> Can you please check if Cartaro is working as expected?
> Thanks,
> Angelos
> On 06/10/2013 05:28 PM, Patric Hafner | geOps wrote:
>> Hi,
>> Am 10.06.2013 01:35, schrieb Angelos Tzotsos:
>>> Only GeoNetwork has an internal GeoServer installation.
>>> MapProxy, Sahana and Cartaro all use the stock GeoServer.
>> For Cartaro, I can confirm this. Are there already any plans which
>> version of GeoServer should be included ?
>> For us, it is very important to know it as soon as possible, as there
>> are some important changes between the 2.2.X and the 2.3.X series which
>> may also affects other projects.
>> With best regards,
>> Patric
>> We are hiring: http://www.geops.de/jobs
Cameron Shorter
Geospatial Solutions Manager
Tel: +61 (0)2 8570 5050
Mob: +61 (0)419 142 254
Think Globally, Fix Locally
Geospatial Solutions enhanced with Open Standards and Open Source
http://www.lisasoft.com
More information about the Live-demo mailing list
