[Live-demo] [OSGeo] #1129: GeoNetwork includes internal GeoServer
OSGeo trac_osgeo at osgeo.org
Tue Jun 18 06:42:37 PDT 2013
 Reporter:  kalxas   |       Owner:  live-demo@…
     Type:  defect   |      Status:  new
 Priority:  major    |   Milestone:  OSGeoLive7.0
Component:  LiveDVD  |    Keywords:
Comment(by kalxas):
 Thanks for the fix.
 This is the log of 10181 build:
 2013-06-18 09:32:29 (16.7 MB/s) - `geonetwork-install-2.10.0-0.jar' saved
 [337520946/337520946]
 `/usr/local/share/gisvm/bin/../app-conf/geonetwork/install.xml' ->
 `./install.xml'
 `/usr/local/share/gisvm/bin/../app-conf/geonetwork/jetty.xml' ->
 `./jetty.xml'
 `/usr/local/share/gisvm/bin/../app-conf/geonetwork/config-gui.xml' ->
 `./config-gui.xml'
 `/usr/local/share/gisvm/bin/../app-conf/geonetwork/start-geonetwork.sh' ->
 `./start-geonetwork.sh'
 `/usr/local/share/gisvm/bin/../app-conf/geonetwork/stop-geonetwork.sh' ->
 `./stop-geonetwork.sh'
 `/usr/local/share/gisvm/bin/../app-conf/geonetwork/data-db-default.sql' ->
 `./data-db-default.sql'
 `/usr/local/share/gisvm/bin/../app-conf/geonetwork/iso-19139-basins-in-
 africa.mef' -> `./iso-19139-basins-in-africa.mef'
 conf/geonetwork/iso-19139-physiographic.mef' ->
 `./iso-19139-physiographic.mef'
 [ Starting automated installation ]
 Read pack list from xml definition.
 Try to add to selection [Name: Core and Index: 0]
 Try to remove from selection [Name: GeoServer and Index: 1]
 Try to remove from selection [Name: European Union INSPIRE Directive
 configuration pack and Index: 2]
 Try to remove from selection [Name: GAST and Index: 3]
 Modify pack selection.
 Pack [Name: GeoServer and Index: 1] removed from selection.
 Pack [Name: European Union INSPIRE Directive configuration pack and Index:
 2] removed from selection.
 Pack [Name: GAST and Index: 3] removed from selection.
 [ Starting to unpack ]
 [ Processing package: Core (1/1) ]
 [ Unpacking finished ]
 [ Creating shortcuts ....... done. ]
 [ Add shortcuts to uninstaller  done. ]
 [ Writing the uninstaller data ... ]
 [ Automated installation done ]
 The user `user' is already a member of `users'.
 conf/geonetwork/start_geonetwork.desktop' -> `./start_geonetwork.desktop'
 conf/geonetwork/stop_geonetwork.desktop' -> `./stop_geonetwork.desktop'
 `/usr/local/share/gisvm/bin/../app-conf/geonetwork/geonetwork.desktop' ->
 `./geonetwork.desktop'
 The problem is that after GN startup, the home ican leads to the following
 404 error (see screenshot)
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/1129#comment:4>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo mailing list
