[Live-demo] [OSGeo] #1062: Cartaro, EOxServer and Geomajas should be in submenus
OSGeo trac_osgeo at osgeo.org
Wed Jun 19 14:40:57 PDT 2013
 Reporter:  hamish   |       Owner:  hamish
     Type:  defect   |      Status:  new
 Priority:  normal   |   Milestone:  OSGeoLive7.0
Component:  LiveDVD  |    Keywords:  cartaro, geomajas, menus, 70
Comment(by hamish):
 Replying to [comment:3 kalxas]:
 > Hi, the fix committed in [10196] is not working as expected
 > (tested in build 10204).
 hopefully enabled in r10210.
 > Also, EOxServer has the same issue.
 for EOxServer I question if the link to the pdf docs needs to be in the
 menu at all, the pdf is nice, but the help is right there in front of you
 once you start the program with the other menu item. (I'm not strictly
 against it, just trying to keep things simple)
 thanks,
 Hamish
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/1062#comment:4>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo mailing list
