[Live-demo] pywps to osgeo-live
Jachym Cepicky jachym.cepicky at gmail.com
Fri Aug 1 13:46:07 PDT 2014
I've updated the installation script in svn and did some minor fix in
the overview file for PyWPS
Jachym
P.S. If I did not stated this yet: It's clear, PyWPS will most likely
not included in next release, which is ok.
2014-07-28 1:03 GMT+02:00 Jachym Cepicky <jachym.cepicky at gmail.com>:
> Hi,
> I've created overview and quickstart pages and added them to svn
> repository (along with logo). I hope, it looks good (?) Sorry, if I
> should not commit (because of feature freeze phase), I was actually
> wondering, whether I have svn-write access (apparently yes).
> About the questions:
> H1: Please describe your application.
> Q1: What is its name?
> A1: PyWPS
> Q2: What is the home page URL?
> A2: http://pywps.wald.invation.org
> Q3: Which OSI approved Open Source Licence is used?
> A3: GNU/GPL
> Q4: What does the application do and how does it add value to the
> GeoSpatial stack of software?
> A4: Implementation of OGC WPS on server side, pure Python, easy and
> fast to setup
> Q5: Does the application make use of OGC standards? Which versions of
> the standards? Client or server? You may wish to add comments about
> how standards are used.
> A5: OGC WPS, 1.0.0, Server
> Q6: What language is it written in?
> A6: Python
> Q7: Which version of the application should be included in the next
> OSGeo-Live release?
> A7: 3.2.2
> H2. Stability is very important to us on OSGeo-Live. If a new user
> finds a bug in one application, it will tarnish the reputation of all
> other OSGeo-Live applications as well. (We pay most attention to the
> following answers):
> Q8: If risk adverse organisations have deployed your application into
> production, it would imply that these organisations have verified the
> stability of your software. Has the application been rolled out to
> production into risk (ideally risk adverse) organisations? Please
> mention some of these organisations?
> A8: According to user feedback, e.g. Allianze Insurance company uses
> PyWPS on it's backend of some applications.
> Q9: Ohloh provides metrics to help assess the health of a project. Eg:
> http://adhoc.osgeo.osuosl.org/livedvd/docs/en/metrics.html Could you
> please ensure that your project is registered with Ohloh, and Ohloh
> has been updated to reference the correct code repository(s) for your
> project. What is the Ohloh URL for your project?
> A9: https://www.openhub.net/p/3860
> Q10: What is the size of the user community? You can often answer this
> by mentioning downloads, or describing a healthy, busy email list?
> A10: 95 Non-digested Members of Pywps-devel, 24 Digested Members of
> Pywps-devel, 23,701 downloads reported by the Wald.intevation.org
> server
> Q11: What is the size of your developer community?
> A11: 2-3 man
> Q12: Do you have a bug free, stable release?
> A12: We hope so
> Q13: Please discuss the level of testing that your project has gone through.
> A13: Mixture of unit and integration tests is applied.
> Q14: How long has the project has had mature code.
> A14: Project was started in 2006 and since then, it aims to provide
> stable and suitable code. Compatibility changes were taken during
> major releases. Currently, new branch (PyWPS-4) is being developed,
> due to heavy changes in geo-python environement.
> Q15: OSGeo-Live is targeted at applications that people can use rather
> than libraries. Does the application have a user interface (possibly a
> command line interface) that a user can interact with? (We do make an
> exception for Incubated OSGeo Libraries, and will include Project
> Overviews for these libraries, even if they don't have a user
> interface.)
> A15: No, just coding & XML
> Q16: We give preference to OSGeo Incubated Projects, or Projects which
> are presented at FOSS4G conferences. If your project is involved in
> OSGeo Incubation, or has been selected to be presented at FOSS4G, then
> please mention it.
> A16: It's in Labs
> Q17: With around 50 applications installed on OSGeo-Live, us core
> packagers do not have the time to liaise with every single project
> email list for each OSGeo-Live release. So we require a volunteer (or
> two) to take responsibility for liaising between OSGeo-Live and the
> project's communities. This volunteer will be responsible for ensuring
> the install scripts and English documentation are updated by someone
> for each OSGeo-Live release. Also test that the installed application
> and Quickstart documentation works as expected on release candidate
> releases of OSGeo-Live. Who will act as the project's liaison person.
> A17: Jachym Cepicky
> H3: OSGeo-Live is Ubuntu Linux based. Our installation preference is:
> Install from UbuntuGIS or DebianGIS
> Install .deb files from a PPA
> Write a custom install script
> Q18: Can you please discuss how your application will be installed.
> A18: Using standard python setup.py script. (The application does not
> have to "installed" at all, can run from source code directory
> directly)
> Q19: OSGeo-Live is memory and disk constrained. Can the application
> run in 512 Meg of RAM?
> A19: The application has very small impact on memory usage
> Q20: How much disk space will be required to install the application
> and a suitable example application?
> A20: Source code has about 6MB code (including documentation)
> Q21: We aim to reduce disk space by having all applications make use
> of a common dataset. We encourage applications to make use of the
> example datasets already installed:
> http://wiki.osgeo.org/wiki/Live_GIS_Add_Project#Example_Datasets If
> another dataset would be more appropriate, please discuss here. Is it
> appropriate, to remove existing demo datasets which may already be
> included in the standard release.
> Q22: Each OSGeo-Live application requires a Project Overview available
> under a CC By and a Quickstart available under a CC By-SA license.
> (You may release under a second license as well). Will you produce
> this?
> A22: In SVN
> Q23: In past releases, we have included Windows and Mac installers for
> some applications. It is likely we won't have space for these in
> future releases. However, if there is room, would you be wishing to
> include Windows and/or Mac installers?
> A23: Standard python setup.py install will be enough, so no need to
> include special installer
> Jachym
> 2014-07-18 22:05 GMT+02:00 Cameron Shorter <cameron.shorter at gmail.com>:
>> Hi Jachym,
>> The details for getting a project onto OSGeo-Live are linked from here:
>> http://wiki.osgeo.org/wiki/Live_GIS_Disc#How_to_add_a_project_to_OSGeoLive
>> As Johan mentions, the first step is to send an email to this list answering
>> our standard questions about the maturity of the project.
>> As it stands, you have missed our feature freeze deadline for the next
>> release, and as such I'm inclined to suggest that pywps shouldn't be
>> publicly included on the next release. (We sometimes do silently include new
>> projects if they are mature enough, such that they can be used in a foss4g
>> workshop or similar, assuming there is sufficient room).
>> On 18/07/2014 11:42 pm, Angelos Tzotsos wrote:
>>> Welcome :)
>>> On Fri, Jul 18, 2014 at 3:31 PM, Jachym Cepicky
>>> <jachym.cepicky at gmail.com> wrote:
>>>> Thanks for pointing me to the fast track
>>>> J
>>>> 2014-07-18 11:27 GMT+02:00 Angelos Tzotsos <gcpp.kalxas at gmail.com>:
>>>>> Hi all,
>>>>> We can initially test this script and commit it under our testing
>>>>> folder until the application gets through.
>>>>> Cheers,
>>>>> Angelos
>>>>> On Fri, Jul 18, 2014 at 11:21 AM, Johan Van de Wauw
>>>>> <johan.vandewauw at gmail.com> wrote:
>>>>>> Jachym,
>>>>>> Thanks for your work.
>>>>>> our sourcecode is under svn (yes, we're old fashioned):
>>>>>> https://svn.osgeo.org/osgeo/livedvd/gisvm/trunk
>>>>>> Not sure if you did this, but in general, we ask you to anser these
>>>>>> questions when applying for a new project:
>>>>>> http://wiki.osgeo.org/wiki/Live_GIS_Disc_Apply
>>>>>> Specifically, make sure you also provide a project overview and a
>>>>>> quickstart.
>>>>>> You may find many of us on freenode irc today under #osgeolive if you
>>>>>> have any more questions.
>>>>>> Johan
>>>>>> On Fri, Jul 18, 2014 at 9:29 AM, Jachym Cepicky
>>>>>>> Hi,
>>>>>>> finally, I managed to create the installation script for PyWPS
>>>>>>> did miss, where shell I submit it?
>>>>>>> https://gist.github.com/jachym/0701ffcb8c7035476dd7
>>>>>>> thanks
>>>>>>> Jachym
>>>>>>> Jachym Cepicky
>>>>>>> e-mail: jachym.cepicky gmail com
>>>>>>> URL: http://les-ejk.cz
>>>>>>> GPG: http://les-ejk.cz/pgp/JachymCepicky.pgp
>>>>>>> _______________________________________________
>>>>>>> Live-demo mailing list
>>>>>>> Live-demo at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/live-demo
>>>>>>> http://live.osgeo.org
>>>>> Angelos Tzotsos
>>>>> Remote Sensing Laboratory
>>>>> National Technical University of Athens
>>>>> http://users.ntua.gr/tzotsos
>>>> Jachym Cepicky
>> Cameron Shorter,
>> Software and Data Solutions Manager
>> LISAsoft
>> Suite 112, Jones Bay Wharf,
>> 26 - 32 Pirrama Rd, Pyrmont NSW 2009
>> P +61 2 9009 5000,  W www.lisasoft.com,  F +61 2 9009 5099
> Jachym Cepicky
> Give your code freedom with PyWPS - http://pywps.wald.intevation.org
Jachym Cepicky
More information about the Live-demo mailing list
