[Live-demo] pywps to osgeo-live
Cameron Shorter
cameron.shorter at gmail.com
Sun Aug 3 13:50:24 PDT 2014
Hi Jachym,
I've read through your answers to questions below, and well as your
Project Overview and Quickstart and I think that PyWPS is a good
candidate for OSGeo-Live in the future, but I don't think it is ready yet.
In particular, I think it is still difficult for a new user to quickly
understand use case that PyWPS fills, and then to quickly assess whether
PyWPS is an established and stable application or not.
(Assume a new user is just as likely to be a manager or architect with
little specific domain expertise).
What I think will help a lot is a web interface to pyWPS bundled with
the application showing examples. Something like the GeoServer web
interface would be perfect, although it need not be quite as
comprehensive at first.
Ideally someone should be able to set up pyWPS for some use cases
without writing any code.
I admit that I've only had a precursory review, but thought it might be
helpful to get some early feedback.
On 28/07/2014 9:03 am, Jachym Cepicky wrote:
> Hi,
> I've created overview and quickstart pages and added them to svn
> repository (along with logo). I hope, it looks good (?) Sorry, if I
> should not commit (because of feature freeze phase), I was actually
> wondering, whether I have svn-write access (apparently yes).
> About the questions:
> H1: Please describe your application.
> Q1: What is its name?
> A1: PyWPS
> Q2: What is the home page URL?
> A2: http://pywps.wald.invation.org
> Q3: Which OSI approved Open Source Licence is used?
> A3: GNU/GPL
> Q4: What does the application do and how does it add value to the
> GeoSpatial stack of software?
> A4: Implementation of OGC WPS on server side, pure Python, easy and
> fast to setup
> Q5: Does the application make use of OGC standards? Which versions of
> the standards? Client or server? You may wish to add comments about
> how standards are used.
> A5: OGC WPS, 1.0.0, Server
> Q6: What language is it written in?
> A6: Python
> Q7: Which version of the application should be included in the next
> OSGeo-Live release?
> A7: 3.2.2
> H2. Stability is very important to us on OSGeo-Live. If a new user
> finds a bug in one application, it will tarnish the reputation of all
> other OSGeo-Live applications as well. (We pay most attention to the
> following answers):
> Q8: If risk adverse organisations have deployed your application into
> production, it would imply that these organisations have verified the
> stability of your software. Has the application been rolled out to
> production into risk (ideally risk adverse) organisations? Please
> mention some of these organisations?
> A8: According to user feedback, e.g. Allianze Insurance company uses
> PyWPS on it's backend of some applications.
> Q9: Ohloh provides metrics to help assess the health of a project. Eg:
> http://adhoc.osgeo.osuosl.org/livedvd/docs/en/metrics.html Could you
> please ensure that your project is registered with Ohloh, and Ohloh
> has been updated to reference the correct code repository(s) for your
> project. What is the Ohloh URL for your project?
> A9: https://www.openhub.net/p/3860
> Q10: What is the size of the user community? You can often answer this
> by mentioning downloads, or describing a healthy, busy email list?
> A10: 95 Non-digested Members of Pywps-devel, 24 Digested Members of
> Pywps-devel, 23,701 downloads reported by the Wald.intevation.org
> server
> Q11: What is the size of your developer community?
> A11: 2-3 man
> Q12: Do you have a bug free, stable release?
> A12: We hope so
> Q13: Please discuss the level of testing that your project has gone through.
> A13: Mixture of unit and integration tests is applied.
> Q14: How long has the project has had mature code.
> A14: Project was started in 2006 and since then, it aims to provide
> stable and suitable code. Compatibility changes were taken during
> major releases. Currently, new branch (PyWPS-4) is being developed,
> due to heavy changes in geo-python environement.
> Q15: OSGeo-Live is targeted at applications that people can use rather
> than libraries. Does the application have a user interface (possibly a
> command line interface) that a user can interact with? (We do make an
> exception for Incubated OSGeo Libraries, and will include Project
> Overviews for these libraries, even if they don't have a user
> interface.)
> A15: No, just coding & XML
> Q16: We give preference to OSGeo Incubated Projects, or Projects which
> are presented at FOSS4G conferences. If your project is involved in
> OSGeo Incubation, or has been selected to be presented at FOSS4G, then
> please mention it.
> A16: It's in Labs
> Q17: With around 50 applications installed on OSGeo-Live, us core
> packagers do not have the time to liaise with every single project
> email list for each OSGeo-Live release. So we require a volunteer (or
> two) to take responsibility for liaising between OSGeo-Live and the
> project's communities. This volunteer will be responsible for ensuring
> the install scripts and English documentation are updated by someone
> for each OSGeo-Live release. Also test that the installed application
> and Quickstart documentation works as expected on release candidate
> releases of OSGeo-Live. Who will act as the project's liaison person.
> A17: Jachym Cepicky
> H3: OSGeo-Live is Ubuntu Linux based. Our installation preference is:
> Install from UbuntuGIS or DebianGIS
> Install .deb files from a PPA
> Write a custom install script
> Q18: Can you please discuss how your application will be installed.
> A18: Using standard python setup.py script. (The application does not
> have to "installed" at all, can run from source code directory
> directly)
> Q19: OSGeo-Live is memory and disk constrained. Can the application
> run in 512 Meg of RAM?
> A19: The application has very small impact on memory usage
> Q20: How much disk space will be required to install the application
> and a suitable example application?
> A20: Source code has about 6MB code (including documentation)
> Q21: We aim to reduce disk space by having all applications make use
> of a common dataset. We encourage applications to make use of the
> example datasets already installed:
> http://wiki.osgeo.org/wiki/Live_GIS_Add_Project#Example_Datasets If
> another dataset would be more appropriate, please discuss here. Is it
> appropriate, to remove existing demo datasets which may already be
> included in the standard release.
> Q22: Each OSGeo-Live application requires a Project Overview available
> under a CC By and a Quickstart available under a CC By-SA license.
> (You may release under a second license as well). Will you produce
> this?
> A22: In SVN
> Q23: In past releases, we have included Windows and Mac installers for
> some applications. It is likely we won't have space for these in
> future releases. However, if there is room, would you be wishing to
> include Windows and/or Mac installers?
> A23: Standard python setup.py install will be enough, so no need to
> include special installer
> Jachym
> 2014-07-18 22:05 GMT+02:00 Cameron Shorter <cameron.shorter at gmail.com>:
>> Hi Jachym,
>> The details for getting a project onto OSGeo-Live are linked from here:
>> http://wiki.osgeo.org/wiki/Live_GIS_Disc#How_to_add_a_project_to_OSGeoLive
>> As Johan mentions, the first step is to send an email to this list answering
>> our standard questions about the maturity of the project.
>> As it stands, you have missed our feature freeze deadline for the next
>> release, and as such I'm inclined to suggest that pywps shouldn't be
>> publicly included on the next release. (We sometimes do silently include new
>> projects if they are mature enough, such that they can be used in a foss4g
>> workshop or similar, assuming there is sufficient room).
>> On 18/07/2014 11:42 pm, Angelos Tzotsos wrote:
>>> Welcome :)
>>> On Fri, Jul 18, 2014 at 3:31 PM, Jachym Cepicky
>>> <jachym.cepicky at gmail.com> wrote:
>>>> Thanks for pointing me to the fast track
>>>> J
>>>> 2014-07-18 11:27 GMT+02:00 Angelos Tzotsos <gcpp.kalxas at gmail.com>:
>>>>> Hi all,
>>>>> We can initially test this script and commit it under our testing
>>>>> folder until the application gets through.
>>>>> Cheers,
>>>>> Angelos
>>>>> On Fri, Jul 18, 2014 at 11:21 AM, Johan Van de Wauw
>>>>> <johan.vandewauw at gmail.com> wrote:
>>>>>> Jachym,
>>>>>> Thanks for your work.
>>>>>> our sourcecode is under svn (yes, we're old fashioned):
>>>>>> https://svn.osgeo.org/osgeo/livedvd/gisvm/trunk
>>>>>> Not sure if you did this, but in general, we ask you to anser these
>>>>>> questions when applying for a new project:
>>>>>> http://wiki.osgeo.org/wiki/Live_GIS_Disc_Apply
>>>>>> Specifically, make sure you also provide a project overview and a
>>>>>> quickstart.
>>>>>> You may find many of us on freenode irc today under #osgeolive if you
>>>>>> have any more questions.
>>>>>> Johan
>>>>>> On Fri, Jul 18, 2014 at 9:29 AM, Jachym Cepicky
>>>>>>> Hi,
>>>>>>> finally, I managed to create the installation script for PyWPS
>>>>>>> did miss, where shell I submit it?
>>>>>>> https://gist.github.com/jachym/0701ffcb8c7035476dd7
>>>>>>> thanks
>>>>>>> Jachym
>>>>>>> Jachym Cepicky
>>>>>>> e-mail: jachym.cepicky gmail com
>>>>>>> URL: http://les-ejk.cz
>>>>>>> GPG: http://les-ejk.cz/pgp/JachymCepicky.pgp
>>>>>>> _______________________________________________
>>>>>>> Live-demo mailing list
>>>>>>> Live-demo at lists.osgeo.org
>>>>>>> http://lists.osgeo.org/mailman/listinfo/live-demo
>>>>>>> http://live.osgeo.org
>>>>> Angelos Tzotsos
>>>>> Remote Sensing Laboratory
>>>>> National Technical University of Athens
>>>>> http://users.ntua.gr/tzotsos
>>>> Jachym Cepicky
>> Cameron Shorter,
>> Software and Data Solutions Manager
>> LISAsoft
>> Suite 112, Jones Bay Wharf,
>> 26 - 32 Pirrama Rd, Pyrmont NSW 2009
>> P +61 2 9009 5000, W www.lisasoft.com, F +61 2 9009 5099
Cameron Shorter,
LISAsoft
More information about the Live-demo
