[Live-demo] [OSGeo] #1386: sahaha: login fails
OSGeo trac_osgeo at osgeo.org
Sat Aug 9 23:26:51 PDT 2014
 Reporter:  hamish   |       Owner:  live-demo@…
     Type:  defect   |      Status:  new
 Priority:  major    |   Milestone:  OSGeoLive8.0
Component:  LiveDVD  |    Keywords:  sahana
 using the credentials given in the quickstart (and install script AFAICS)
 it's not possible to login to the admin side of the sahana example on the
 live disc.
 not a good look.
 there are some error messages in the build log worth investigating.
  http://aiolos.survey.ntua.gr/gisvm/dev/
 python: no process found
 WARNING: S3Chart unresolved dependency: matplotlib required for charting
 WARNING: S3Msg unresolved dependency: tweepy required for non-Tropo
 Twitter support
 WARNING: Survey unresolved dependency: PyRTF required if you want to
 export assessment templates as a Word document
   File "/usr/local/lib/web2py/gluon/restricted.py", line 212, in
 restricted
     exec ccode in environment
   File "applications/eden/models/zzz_1st_run.py", line 177, in <module>
     resource.import_xml(File, format="csv", stylesheet=stylesheet)
   File "applications/eden/modules/s3/s3resource.py", line 2465, in
 import_xml
     raise SyntaxError(xml.error)
 SyntaxError: Forbidden variable
 ./install_sahana.sh: 317: ./install_sahana.sh: cannot create
 /etc/apache2/conf.d/sahana: Directory nonexistent
 what has /etc/apache2/conf.d/ changed to for ubuntu 14.04?
 thanks,
 Hamish
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1386>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo mailing list
