[Live-demo] [OSGeo] #1383: qgis_server demo brings the OSGeo Live VM down
OSGeo trac_osgeo at osgeo.org
Tue Aug 19 11:36:17 PDT 2014
 Reporter:  rouault  |       Owner:  live-demo@…
     Type:  defect   |      Status:  new
 Priority:  normal   |   Milestone:  OSGeoLive8.0
Component:  LiveDVD  |    Keywords:  qgis_server
Comment(by larrysh):
 Should be fixed with changeset:11927 Will issue reporter please verify?
 However, the use of Apache with mod_fcgid is not an ideal setup for
 qgis_mapserv.fcgi. It runs much better under mod_fastcgi, but that can not
 be installed alongside of mod_fcgid at the same time.
 Also, I test with lighttpd, as is used for the labeling unit tests in QGIS
 source, and the demo is lightning fast, with very little resources used
 when compared to Apache. I feel this is a more appropriate means of
 demoing the QGIS Server, especially if the web client is upgraded to use
 [https://github.com/qgis/QGIS-Web-Client QGIS Web Client] (which it should
 be).
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/1383#comment:9>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo mailing list
