[Live-demo] [OSGeo] #1394: uDig: fails to start on first launch
OSGeo trac_osgeo at osgeo.org
Thu Aug 21 04:29:08 PDT 2014
 Reporter:  hamish   |       Owner:  live-demo@…
     Type:  defect   |      Status:  new
 Priority:  normal   |   Milestone:  OSGeoLive8.0
Component:  LiveDVD  |    Keywords:  udig
Comment(by hamish):
 Here you go:
 Aug 21, 2014 10:25:56 AM
 org.geotools.referencing.factory.PropertyAuthorityFactory <init>
 WARNING: Axis elements found in a wkt definition, the force longitude
 first axis order hint might not be respected:
 PROJCS["Monte Mario / Italy zone 1 - Sicily/Accuracy 3-4m", GEOGCS["Monte
 Mario", DATUM["Monte Mario", SPHEROID["International 1924", 6378388.0,
 297.0, AUTHORITY["EPSG","7022"]],
 TOWGS84[-50.2,-50.4,84.8,-0.690,-2.012,0.459,-28.08],
 AUTHORITY["EPSG","6265"]], PRIMEM["Greenwich", 0.0,
 AUTHORITY["EPSG","8901"]], UNIT["degree", 0.017453292519943295],
 AXIS["Geodetic longitude", EAST], AXIS["Geodetic latitude", NORTH],
 AUTHORITY["EPSG","4265"]], PROJECTION["Transverse_Mercator"],
 PARAMETER["central_meridian", 9.0], PARAMETER["latitude_of_origin", 0.0],
 PARAMETER["scale_factor", 0.9996], PARAMETER["false_easting", 1500000.0],
 PARAMETER["false_northing", 0.0], UNIT["m", 1.0], AXIS["Easting", EAST],
 AXIS["Northing", NORTH], AUTHORITY["EPSG","30031002"]]
 /usr/bin/udig: line 29:  4215 Aborted                 (core dumped)
 $PRGDIR/udig_internal -data ~/uDigWorkspace $@
 # A fatal error has been detected by the Java Runtime Environment:
 #  SIGSEGV (0xb) at pc=0xade3686d, pid=4215, tid=3075598080
 # JRE version: OpenJDK Runtime Environment (7.0_65-b32) (build
 1.7.0_65-b32)
 # Java VM: OpenJDK Client VM (24.65-b04 mixed mode, sharing linux-x86 )
 # Problematic frame:
 # C  [libsoup-2.4.so.1+0x5486d]  soup_session_feature_detach+0x1d
 # Failed to write core dump. Core dumps have been disabled. To enable core
 dumping, try "ulimit -c unlimited" before starting Java again
 # An error report file with more information is saved as:
 # /home/user/hs_err_pid4215.log
 # If you would like to submit a bug report, please include
 # instructions on how to reproduce the bug and visit:
 #   http://icedtea.classpath.org/bugzilla
 # The crash happened outside the Java Virtual Machine in native code.
 # See problematic frame for where to report the bug.
 !SESSION 2014-08-21 10:25:45.748
 eclipse.buildId=unknown
 java.version=1.7.0_65
 java.vendor=Oracle Corporation
 BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=en_US
 Command-line arguments:  -os linux -ws gtk -arch x86 -data
 /home/user/uDigWorkspace
 !ENTRY net.refractions.udig.ui 1 0 2014-08-21 10:26:01.116
 !MESSAGE net.refractions.udig.ui.WorkbenchConfiguration
 "net.refractions.udig.internal.ui.UDIGWorkbenchConfiguration" specified
 but no valid extension found.
 Please check that the extension exists and that it is valid.
 !ENTRY net.refractions.udig.ui 1 0 2014-08-21 10:26:01.159
 !MESSAGE net.refractions.udig.ui.MenuBuilder
 "net.refractions.udig.ui.uDigMenuBuilder" specified but no valid extension
 found.
 !ENTRY net.refractions.udig.catalog 4 0 2014-08-21 10:26:02.145
 !MESSAGE Restoring Local Catalog
 I tried '`rm -r ~/udigWorkspace/.metadata`' and it crashed every time,
 until the third time when it not only froze my VM but also the X-Windows
 on my host and I had to reboot! Then I stopped testing. :-)
 sorry, the ~/hs_err_pid4215.log was lost in the reboot. The progress bar
 in the startup splash screen got about half way across, to the middle of
 the word "Desktop"
 Hamish
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/1394#comment:2>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo mailing list
