[Live-demo] [OSGeo] #1399: OpemJUMP fails on system with more than	4gb ram
    OSGeo
    trac_osgeo at osgeo.org
    Fri Aug 22 21:12:39 PDT 2014
 Reporter:  hamish   |       Owner:  live-demo@…
     Type:  defect   |      Status:  new
 Priority:  major    |   Milestone:  OSGeoLive8.0
Component:  LiveDVD  |    Keywords:  openjump
 For the OSGeoLive 8.0 disc we use 32bit Lubuntu with the linux pae
 extensions, allowing the OS (but not processes) to access to more than 4gb
 ram.
 On a test of the 8.0 mini on a system with 16gb ram, or a VM with 5gb RAM,
 OpenJUMP fails to start.
 If you try from the command line you get the following error message:
 $ openjump
 limit max. memory to 3072 MiB
 Running -> '/usr/lib/jvm/java-7-openjdk-i386/jre/bin/java';  java version
 "1.7.0_65"; OpenJDK Runtime Environment (IcedTea 2.5.1)
 (7u65-2.5.1-4ubuntu1~0.14.04.1); OpenJDK Server VM (build 24.65-b04, mixed
 mode);
 Error occurred during initialization of VM
 Could not reserve enough space for object heap
 Error: Could not create the Java Virtual Machine.
 Error: A fatal exception has occurred. Program will exit.
 press Enter to finish
 Looking in the /usr/bin/openjump startup script I see some special 32bit
 $MEM_MAX logic. If I change the value there for max on 32bit down to
 2716000000, or simply comment out the JAVA_MAXMEM line, then it starts up
 ok.
 thanks,
 Hamish
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1399>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo
