[Live-demo] FOSS4G Workshop
Daniel Kastl daniel at georepublic.de
Sat Aug 30 04:35:12 PDT 2014
Thanks, Angelos!
As I said, I didn't remember details of previous releases. I just thought
that when I started the VM in previous versions, then the initial screen
was larger, so probably I didn't install the Guest Additions at all. Do you
think the change to Lubuntu could be the reason?
Daniel
On Sat, Aug 30, 2014 at 1:11 PM, Angelos Tzotsos <gcpp.kalxas at gmail.com>
wrote:
>  Hi Daniel,
> We never install any additions to the VM to avoid conflicts between
> Hypervisors.
> What we do is install the kernel headers to support building kernel
> modules.
> So in order to support VBox it would be needed to add the vbox kernel
> module and then deploy the VM to the workshop machines.
> Best,
> Angelos
> On 08/30/2014 01:30 PM, Daniel Kastl wrote:
> Hi Daniel,
> I just wanted to give you some update regarding (my) workshop(s) using
> OSGeo Live. I have just tested the final release of OSGeo Live, using the
> Virtual Machine image: http://live.osgeo.org/en/download.html
> I guess, the Virtual Machine image will be the one installed on the
> workshop PC's, right? I think it's the best choice, but I found out, that
> the initial screen resolution is just 800x600 as far as I remember. It
> would be necessary to install the Virtual Box Guest Additions, which seem
> not to be installed by default. I thought it was the case in previous
> releases, but that might be wrong.
> With 800x600 px screen resolution it's pretty hard to work. Do you think it
> will be possible to have the Virtual Box Guest Additions installed on the
> workshop PC's?
> Many thanks,
> Daniel
> Live-demo mailing listLive-demo at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/live-demohttp://live.osgeo.orghttp://wiki.osgeo.org/wiki/Live_GIS_Disc
> Angelos Tzotsos
> Remote Sensing Laboratory
> National Technical University of Athenshttp://users.ntua.gr/tzotsos
Georepublic UG & Georepublic Japan
eMail: daniel.kastl at georepublic.de
Web: http://georepublic.info
URL: <http://lists.osgeo.org/pipermail/live-demo/attachments/20140830/53793463/attachment.html>
More information about the Live-demo mailing list
