[Live-demo] [OSGeo] #1428: Include GeoPandas on Live 8.5
OSGeo trac_osgeo at osgeo.org
Sun Dec 14 12:19:35 PST 2014
 Reporter:  darkblueb    |       Owner:  live-demo@…
     Type:  enhancement  |      Status:  new
 Priority:  normal       |   Milestone:  OSGeoLive8.5
Component:  LiveDVD      |    Keywords:  python, GeoPandas
Comment(by darkblueb):
 '''kalxas''' has added a GeoPandas package earlier this year, but it is
 one version previous.. the Descarte plotting utility may need to be added
 as a dependancy.. Here is a detailed comparison between the GeoPandas
 package and what is commonly available today:
 user at live12014:~$ locate geopandas
 /usr/local/lib/python2.7/dist-packages/geopandas
 /usr/local/lib/python2.7/dist-packages/geopandas-0.1.1.egg-info
 /usr/local/lib/python2.7/dist-packages/geopandas/__init__.py
 /usr/local/lib/python2.7/dist-packages/geopandas/__init__.pyc
 /usr/local/lib/python2.7/dist-packages/geopandas/base.py
 /usr/local/lib/python2.7/dist-packages/geopandas/base.pyc
 /usr/local/lib/python2.7/dist-packages/geopandas/geocode.py
 /usr/local/lib/python2.7/dist-packages/geopandas/geocode.pyc
 /usr/local/lib/python2.7/dist-packages/geopandas/geodataframe.py
 /usr/local/lib/python2.7/dist-packages/geopandas/geodataframe.pyc
 /usr/local/lib/python2.7/dist-packages/geopandas/geoseries.py
 /usr/local/lib/python2.7/dist-packages/geopandas/geoseries.pyc
 /usr/local/lib/python2.7/dist-packages/geopandas/io
 /usr/local/lib/python2.7/dist-packages/geopandas/plotting.py
 /usr/local/lib/python2.7/dist-packages/geopandas/plotting.pyc
 /usr/local/lib/python2.7/dist-packages/geopandas/version.py
 /usr/local/lib/python2.7/dist-packages/geopandas/version.pyc
 /usr/local/lib/python2.7/dist-packages/geopandas/io/__init__.py
 /usr/local/lib/python2.7/dist-packages/geopandas/io/__init__.pyc
 /usr/local/lib/python2.7/dist-packages/geopandas/io/file.py
 /usr/local/lib/python2.7/dist-packages/geopandas/io/file.pyc
 /usr/local/lib/python2.7/dist-packages/geopandas/io/sql.py
 /usr/local/lib/python2.7/dist-packages/geopandas/io/sql.pyc
 /usr/local/lib/python2.7/dist-packages/geopandas-0.1.1.egg-info/PKG-INFO
 info/SOURCES.txt
 info/dependency_links.txt
 /usr/local/lib/python2.7/dist-packages/geopandas-0.1.1.egg-info/installed-
 files.txt
 info/requires.txt
 info/top_level.txt
 user at live12014:~$ ls /usr/local/lib/python2.7/dist-packages/geopandas
 base.py     geocode.pyc       geoseries.py   __init__.pyc  plotting.pyc
 base.pyc    geodataframe.py   geoseries.pyc  io/           version.py
 geocode.py  geodataframe.pyc  __init__.py    plotting.py   version.pyc
 user at live12014:~$ dpkg --info python-geopandas_0.1.0-0~trusty2_i386.deb
  new debian package, version 2.0.
  size 16108 bytes: control archive=1288 bytes.
      473 bytes,    13 lines      control
     1648 bytes,    18 lines      md5sums
      166 bytes,     9 lines   *  postinst             #!/bin/sh
      269 bytes,    14 lines   *  prerm                #!/bin/sh
  Package: python-geopandas
  Source: geopandas
  Version: 0.1.0-0~trusty2
  Architecture: i386
  Maintainer: Angelos Tzotsos <gcpp.kalxas at gmail.com>
  Installed-Size: 104
  Depends: python (>= 2.7), python-shapely, python-fiona, python-pyproj,
 python-six, python-rtree, python-numpy, python-pandas, debconf
  Section: science
  Priority: optional
  Homepage: https://github.com/geopandas/geopandas
  Description: This package contains the geopandas library
   Python tools for geographic data
 user at live12014:~$ mv python-geopandas_0.1.0-0~trusty2_i386.deb tmp/
 user at live12014:~$ cd tmp
 user at live12014:~/tmp$ dpkg -X python-geopandas_0.1.0-0~trusty2_i386.deb  .
 ./usr/
 ./usr/lib/
 ./usr/lib/python2.7/
 ./usr/lib/python2.7/dist-packages/
 ./usr/lib/python2.7/dist-packages/geopandas/
 ./usr/lib/python2.7/dist-packages/geopandas/plotting.py
 ./usr/lib/python2.7/dist-packages/geopandas/tools.py
 ./usr/lib/python2.7/dist-packages/geopandas/base.py
 ./usr/lib/python2.7/dist-packages/geopandas/io/
 ./usr/lib/python2.7/dist-packages/geopandas/io/file.py
 ./usr/lib/python2.7/dist-packages/geopandas/io/sql.py
 ./usr/lib/python2.7/dist-packages/geopandas/io/__init__.py
 ./usr/lib/python2.7/dist-packages/geopandas/geodataframe.py
 ./usr/lib/python2.7/dist-packages/geopandas/geocode.py
 ./usr/lib/python2.7/dist-packages/geopandas/geoseries.py
 ./usr/lib/python2.7/dist-packages/geopandas/__init__.py
 ./usr/lib/python2.7/dist-packages/geopandas/version.py
 ./usr/lib/python2.7/dist-packages/geopandas-0.1.0.egg-info/
 ./usr/lib/python2.7/dist-packages/geopandas-0.1.0.egg-info/PKG-INFO
 ./usr/lib/python2.7/dist-packages/geopandas-0.1.0.egg-info/top_level.txt
 ./usr/lib/python2.7/dist-packages/geopandas-0.1.0.egg-info/requires.txt
 ./usr/lib/python2.7/dist-packages/geopandas-0.1.0.egg-info/SOURCES.txt
 ./usr/share/
 ./usr/share/doc/
 ./usr/share/doc/python-geopandas/
 ./usr/share/doc/python-geopandas/copyright
 ./usr/share/doc/python-geopandas/changelog.Debian.gz
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/1428#comment:1>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo mailing list
