[Live-demo] [OSGeo] #1437: OL3 fails to install
OSGeo trac_osgeo at osgeo.org
Sun Dec 28 11:54:06 PST 2014
 Reporter:  kalxas    |       Owner:  live-demo@…
     Type:  defect    |      Status:  new
 Priority:  critical  |   Milestone:  OSGeoLive8.5
Component:  LiveDVD   |    Keywords:
Comment(by kalxas):
 Some packages could not be installed. This may mean that you have
 requested an impossible situation or if you are using the unstable
 distribution that some required packages have not yet been created
 or been moved out of Incoming.
 The following information may help to resolve the situation:
 The following packages have unmet dependencies:
  npm : Depends: nodejs but it is not going to be installed
        Depends: node-abbrev (>= 1.0.4) but it is not going to be installed
        Depends: node-ansi but it is not going to be installed
        Depends: node-archy but it is not going to be installed
        Depends: node-block-stream but it is not going to be installed
        Depends: node-fstream (>= 0.1.22) but it is not going to be
 installed
        Depends: node-fstream-ignore but it is not going to be installed
        Depends: node-github-url-from-git but it is not going to be
 installed
        Depends: node-glob (>= 3.1.21) but it is not going to be installed
        Depends: node-graceful-fs (>= 2.0.0) but it is not going to be
 installed
        Depends: node-inherits but it is not going to be installed
        Depends: node-ini (>= 1.1.0) but it is not going to be installed
        Depends: node-lockfile but it is not going to be installed
        Depends: node-lru-cache (>= 2.3.0) but it is not going to be
 installed
        Depends: node-minimatch (>= 0.2.11) but it is not going to be
 installed
        Depends: node-mkdirp (>= 0.3.3) but it is not going to be installed
        Depends: node-gyp (>= 0.10.9) but it is not going to be installed
        Depends: node-nopt (>= 2.1.1) but it is not going to be installed
        Depends: node-npmlog but it is not going to be installed
        Depends: node-once but it is not going to be installed
        Depends: node-osenv but it is not going to be installed
        Depends: node-read but it is not going to be installed
        Depends: node-read-package-json (>= 1.1.0) but it is not going to
 be installed
        Depends: node-request (>= 2.25.0) but it is not going to be
 installed
        Depends: node-retry but it is not going to be installed
        Depends: node-rimraf (>= 2.2.2) but it is not going to be installed
        Depends: node-semver (>= 2.1.0) but it is not going to be installed
        Depends: node-sha but it is not going to be installed
        Depends: node-slide but it is not going to be installed
        Depends: node-tar (>= 0.1.18) but it is not going to be installed
        Depends: node-which but it is not going to be installed
 E: Unable to correct problems, you have held broken packages.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/1437#comment:4>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo mailing list
