[Live-demo] [OSGeo] #1442: GeoNode's demo data
OSGeo trac_osgeo at osgeo.org
Wed Dec 31 09:24:51 PST 2014
 Reporter:  kalxas   |       Owner:  live-demo@…
     Type:  defect   |      Status:  new
 Priority:  major    |   Milestone:  OSGeoLive8.5
Component:  LiveDVD  |    Keywords:
Comment(by kalxas):
 GeoNode data still don't get imported:
 Starting GeoServer to update layers in the geonode db
 java.net.ConnectException: Connection refused
         at java.net.PlainSocketImpl.socketConnect(Native Method)
         at
 java.net.AbstractPlainSocketImpl.doConnect(AbstractPlainSocketImpl.java:339)
         at
 java.net.AbstractPlainSocketImpl.connectToAddress(AbstractPlainSocketImpl.java:200)
         at
 java.net.AbstractPlainSocketImpl.connect(AbstractPlainSocketImpl.java:182)
         at java.net.SocksSocketImpl.connect(SocksSocketImpl.java:392)
         at java.net.Socket.connect(Socket.java:579)
         at java.net.Socket.connect(Socket.java:528)
         at java.net.Socket.<init>(Socket.java:425)
         at java.net.Socket.<init>(Socket.java:241)
         at org.mortbay.start.Main.stop(Main.java:526)
         at org.mortbay.start.Main.main(Main.java:104)
 GEOSERVER DATA DIR is /usr/local/lib/geoserver-2.6.1/data_dir
 2014-12-31 14:52:56.361::INFO:  Logging to STDERR via
 org.mortbay.log.StdErrLog
 2014-12-31 14:52:56.554::WARN:  Deprecated configuration used for
 /usr/local/lib/geoserver-2.6.1/webapps
 2014-12-31 14:52:56.595::INFO:  jetty-6.1.8
 Updating GeoNode layers...
   File "/usr/bin/django-admin", line 5, in <module>
     management.execute_from_command_line()
   File "/usr/lib/python2.7/dist-
 packages/django/core/management/__init__.py", line 399, in
     utility.execute()
 packages/django/core/management/__init__.py", line 392, in execute
     self.fetch_command(subcommand).run_from_argv(self.argv)
   File "/usr/lib/python2.7/dist-packages/django/core/management/base.py",
 line 242, in run_from_argv
     self.execute(*args, **options.__dict__)
 line 285, in execute
     output = self.handle(*args, **options)
 packages/geonode/geoserver/management/commands/updatelayers.py", line 108,
 in handle
     remove_deleted=remove_deleted)
   File "/usr/lib/python2.7/dist-packages/geonode/geoserver/helpers.py",
 line 362, in gs_slurp
     resources = cat.get_resources(workspace=workspace)
   File "/usr/lib/python2.7/dist-packages/geoserver/catalog.py", line 639,
 in get_resources
     for ws in self.get_workspaces():
   File "/usr/lib/python2.7/dist-packages/geoserver/catalog.py", line 755,
 in get_workspaces
     description = self.get_xml("%s/workspaces.xml" % self.service_url)
   File "/usr/lib/python2.7/dist-packages/geoserver/catalog.py", line 183,
 in get_xml
     response, content = self.http.request(rest_url)
   File "/usr/lib/python2.7/dist-packages/httplib2/__init__.py", line 1569,
 in request
     (response, content) = self._request(conn, authority, uri, request_uri,
 method, body, headers, redirections, cachekey)
   File "/usr/lib/python2.7/dist-packages/httplib2/__init__.py", line 1316,
 in _request
     (response, content) = self._conn_request(conn, request_uri, method,
 body, headers)
   File "/usr/lib/python2.7/dist-packages/httplib2/__init__.py", line 1251,
 in _conn_request
     conn.connect()
   File "/usr/lib/python2.7/dist-packages/httplib2/__init__.py", line 912,
 in connect
     raise socket.error, msg
 socket.error: [Errno 111] Connection refused
 Done
 Stopping GeoServer
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/1442#comment:3>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo mailing list
