[Live-demo] [OSGeo] #1288: GeoNode 2.0 depends on python-dev (was: GeoNode 2.0 fails to connect to the database)
OSGeo
trac_osgeo at osgeo.org
Mon Feb 24 04:21:20 PST 2014
Reporter: kalxas | Owner: live-demo@…
Type: defect | Status: new
Priority: critical | Milestone: OSGeoLive7.9
Component: LiveDVD | Keywords:
Comment(by kalxas):
After some debugging I found the following:
1. The reason that GeoNode is not working is because the file
/usr/lib/python2.7/dist-packages/geonode/wsgi.py is missing.
2. The reason that the above file is missing is because the package
python-geonode is removed at some point during the build process. If this
is executed on beta3 build, GeoNode will work fine again:
sudo apt-get install python-geonode
3. The reason why python-geonode is removed is because the deb file
depends on python-dev, which is removed during cleanup.
The question is: Why is python-dev needed in python-geonode? I believe
this is a debian packaging bug.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/1288#comment:5>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo
