[Live-demo] [OSGeo] #1298: netCDF et al
OSGeo
trac_osgeo at osgeo.org
Tue Feb 25 18:47:38 PST 2014
#1298: netCDF et al
Reporter: darkblueb | Owner: live-demo@…
Type: enhancement | Status: new
Priority: normal | Milestone: OSGeoLive7.9
Component: LiveDVD | Keywords: python, netCDF
Comment(by darkblueb):
hiebert writes :
With respect to netcdf pacakges in python, Scientific.IO.NetCDF is a pure
python implementation that only handles classic (version 3) NetCDF files.
To my knowledge it is not under active development (like you have noted
with the 6 year old revision date). There is definitely merit to using a
pure python implementation (it can run on different interpreters like PyPy
and Jython, there is no build/linking process, and it's substantially more
portable). However, not handling version 4 NetCDF files can be
problematic.
It's worth noting that the NetCDF4 format is a subset of the HDF5 format,
so you can use either library to open NetCDF4 files. We use the
netcdf4-python and the h5py packages. Both sets of developers are
extremely responsive and I trust their code. We typically install both
using python's pip, rather than relying on the Debian packages.
I hadn't noticed that I only gave you NetCDF 3 files. Hopefully, that's
OK. We use both depending on the needs of the data storage for a
particular project.
Ticket URL: <http://trac.osgeo.org/osgeo/ticket/1298#comment:7>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo
