[Live-demo] [OSGeo] #1362: Ubuntu updates break build process
OSGeo trac_osgeo at osgeo.org
Tue Jul 1 21:49:30 PDT 2014
 Reporter:  kalxas   |       Owner:  live-demo@…
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  OSGeoLive8.0
Component:  LiveDVD  |    Keywords:
Comment(by hamish):
 the "package not found" thing has been there for a long time, so probably
 not related.
 can you bootstrap into the chroot and run setup.sh, then see if DNS is
 working or if 'ifconfig eth0' has lost contact? can you figure a way to
 manually bring it back up from there?
 13 new packages between the 11530 and 11533 builds,
 gnupg
 gpgv
 libgphoto2-6
 libgphoto2-port10
 libspectre1
 light-locker-settings
 lxsession
 lxsession-data
 lxsession-default-apps
 lxsession-logout
 resolvconf
 xfce4-power-manager
 xfce4-power-manager-data
 resolvconf sticks out like a sore thumb, install looks ok:
 Setting up resolvconf (1.69ubuntu1.1) ...
  * Setting up resolvconf...
    ...done.
 maybe it is the same trouble we are having at boot with /etc/resolv.conf
 missing, happening earlier?
 Experiment added in setup.sh, r11539.
 I added the same 'dhclient eth0' workaround I'd previously added the user-
 login xfce autostart* to get DNS working at run time. (no idea how things
 will go with wifi connections yet)
 [*] see install_desktop.sh
 Hamish
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1362#comment:2>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo mailing list
