[Live-demo] UDig broken on OSGeo-Live
Angelos Tzotsos gcpp.kalxas at gmail.com
Tue Jul 29 06:26:34 PDT 2014
A way forward would be to include those manual steps in install_udig.sh
Angelos
On 07/29/2014 02:29 PM, andrea antonello wrote:
>> For some reason I cannot locate a xulrunner available for ubuntu trusty...
> Because it doesn't exist any more in the distribution.
> It looks like it needs to be installed manually:
> http://askubuntu.com/questions/125980/how-do-i-install-xulrunner
> Even if it is simple and can hopefully be done for Osgeo-Live, we will
> need to find a more easy solution for the future.
> Let us know if installing manually is an option.
> Andrea
>> https://launchpad.net/ubuntu/trusty/+source/xulrunner
>> https://launchpad.net/xulrunner
>> On 07/29/2014 06:23 AM, Jody Garnett wrote:
>>> Okay - good test!
>>> So is there an XULrunner that will work with your distribution?
>>> I will also perform a quick check here to ensue the website that page is
>>> trying to load is available.
>>> If not I will make a 1.4.1 pointing at a github page or perhaps we could
>>> make a OsGeo live documentation page with good OGC Web services to use for
>>> demos?
>>>> On Jul 28, 2014, at 10:16 AM, Angelos Tzotsos <gcpp.kalxas at gmail.com>
>>>> wrote:
>>>> Hi,
>>>> In 8.0 alpha4 when I select the "Web" tab, nothing happens...
>>>> Angelos
>>>>> On 07/28/2014 06:45 PM, Jody Garnett wrote:
>>>>> That seems likely, so we have two good ways to test.
>>>>> Any confirmation from the live-demo team if that functionality is still
>>>>> available based on firefox being installed?
>>>>> Jody Garnett
>>>>> On Sun, Jul 27, 2014 at 11:13 PM, andrea antonello <
>>>>> andrea.antonello at gmail.com> wrote:
>>>>>>> Based on previous message the test to confirm if XULRunner was needed
>>>>>> (or if
>>>>>>> it was able to pick up your firefox install?) is to open uDig and
>>>>>>> switch
>>>>>> to
>>>>>>> the "web" tab and see if the embedded browser pops up.
>>>>>> Yes the web view is the point in all this. Which means, if I am not
>>>>>> mistaken, that also WMS info results might be broken?
>>>>>> Andrea
>>>>>>> Jody
>>>>>>> Jody Garnett
>>>>>>> On Sat, Jul 26, 2014 at 9:42 AM, Angelos Tzotsos
>>>>>>> wrote:
>>>>>>>> Hi Jody,
>>>>>>>> The xulrunner package was in the installation script, I have no idea
>>>>>>>> why
>>>>>>>> it was there.
>>>>>>>> If it is not needed, we can remove it (already commented it out)
>>>>>>>> As for the dpkg (Debian package management tool), it was blocked
>>>>>>>> because
>>>>>>>> the above package was broken.
>>>>>>>> Bottom line: The installer seems to be working fine now, I am
>>>>>>>> building a
>>>>>>>> new iso and will ask you to test when available.
>>>>>>>> Best,
>>>>>>>> Angelos
>>>>>>>>> On 07/26/2014 05:48 PM, Jody Garnett wrote:
>>>>>>>>> I do not know what xulrunner or dpgk is?
>>>>>>>>> Given that you have not changed the version of uDig used I think we
>>>>>> need
>>>>>>>>> more information on what has changed in the execution environment.
>>>>>>>>> Jody Garnett
>>>>>>>>>> On 26 Jul 2014, at 5:35 am, Angelos Tzotsos <gcpp.kalxas at gmail.com>
>>>>>>>>>> wrote:
>>>>>>>>>> Hi all,
>>>>>>>>>> The problem currently is that xulrunner is breaking dpgk and
>>>>>>>>>> freezes
>>>>>>>>>> apt.
>>>>>>>>>> I have disabled it as well as the geopublishing ppa which
>>>>>>>>>> apparently
>>>>>> has
>>>>>>>>>> expired.
>>>>>>>>>> Please take a look if this can be fixed upstream.
>>>>>>>>>> Thanks,
>>>>>>>>>> Angelos
>>>>>>>>>>> On 07/26/2014 03:09 PM, Cameron Shorter wrote:
>>>>>>>>>>> Hi Andrea and Jody,
>>>>>>>>>>> It seems that we have a critical issue installing Udig on
>>>>>>>>>>> OSGeo-Live.
>>>>>>>>>>> I wonder if you could help us look into it.
>>>>>>>>>>> https://trac.osgeo.org/osgeo/ticket/1368
>>>>>>>>>>> xulrunner installation breaks dpkg (udig installer)
>>>>>>>>>>> _______________________________________________
>>>>>>>>>>> Live-demo mailing list
>>>>>>>>>>> Live-demo at lists.osgeo.org
>>>>>>>>>>> http://lists.osgeo.org/mailman/listinfo/live-demo
>>>>>>>>>>> http://live.osgeo.org
>>>>>>>>>>> http://wiki.osgeo.org/wiki/Live_GIS_Disc
>>>>>>>>>> Angelos Tzotsos
>>>>>>>>>> Remote Sensing Laboratory
>>>>>>>>>> National Technical University of Athens
>>>>>>>>>> http://users.ntua.gr/tzotsos
>>>>>>>> Angelos Tzotsos
>>>> Angelos Tzotsos
>> Angelos Tzotsos
Angelos Tzotsos
More information about the Live-demo mailing list
