[Live-demo] [OSGeo] #1403: uDig: crash when you click on the 'web' tab
OSGeo trac_osgeo at osgeo.org
Mon Sep 1 13:23:28 PDT 2014
 Reporter:  hamish   |       Owner:  live-demo@…
     Type:  defect   |      Status:  new
 Priority:  normal   |   Milestone:  OSGeoLive8.5
Component:  LiveDVD  |    Keywords:  udig
 start udig (twice), in the lower frame click on the "web" tab.
  -- core dumped --
 # A fatal error has been detected by the Java Runtime Environment:
 #  SIGSEGV (0xb) at pc=0xa51b386d, pid=4034, tid=3076003584
 # JRE version: OpenJDK Runtime Environment (7.0_65-b32) (build
 1.7.0_65-b32)
 # Java VM: OpenJDK Client VM (24.65-b04 mixed mode, sharing linux-x86 )
 # Problematic frame:
 # C  [libsoup-2.4.so.1+0x5486d]  soup_session_feature_detach+0x1d
 # Failed to write core dump. Core dumps have been disabled. To enable core
 dumping, try "ulimit -c unlimited" before starting Java again
 # An error report file with more information is saved as:
 # /home/user/hs_err_pid4034.log
 # If you would like to submit a bug report, please include
 # instructions on how to reproduce the bug and visit:
 #   http://icedtea.classpath.org/bugzilla
 # The crash happened outside the Java Virtual Machine in native code.
 # See problematic frame for where to report the bug.
 /usr/bin/udig: line 29:  4034 Aborted                 (core dumped)
 $PRGDIR/udig_internal -data ~/uDigWorkspace $@
 java traceback contained in hs_err_pid4034.log copied here:
   http://paste.debian.net/118808
 thanks,
 Hamish
Ticket URL: <https://trac.osgeo.org/osgeo/ticket/1403>
OSGeo <http://www.osgeo.org/>
OSGeo committee and general foundation issue tracker.
More information about the Live-demo mailing list
