[Live-demo] Problem with mounting shared folder in OsgeoLive 8.5
Elena Mezzini elena.mezzini at gmail.com
Wed Apr 22 03:52:30 PDT 2015
Dear all,
First of all, thank you for your helpfulness!
Yesterday evening, before my pc shutdown I wasn't able to fullscreen
properly the VM, I had only rebooted the VM, not the pc.
Today, the fullscreen is working properly, so I relunched the command:
sudo mount -t vboxsf -o uid=user, rw LAVORI /home/user/LAVORI
but still not working...
> The other option is as explained on the page you refer to. Did you get
> any errors while executing the scripts?
Yes, in my opinion, due to mistaken commands:
suThis t-get install build-essential linux-headers-generic (as written
in Quickstart) is not working, returning:
suThis: command not found
so I did:
sudo apt-get install build-essential linux-headers-generic
but needs updates, so it's better doing:
sudo apt-get update (as also Johan suggested)
and then:
> Can you post the output of the
> install script?
Doing this, everything seems fine!
Except from the mounting commands...
Now I will try Johan solution:
> sudo apt-get update (makes sure you have the most recent sources)
(already done)
> sudo apt-get install virtualbox-guest-x11 virtualbox-guest-dkms
> virtualbox-guest-utils
I'll let you know in a while!
> This is no longer true. Since December 2010 there is actually only one
> version of Virtualbox and you can install an extension pack which is
> not open source. This only contains extra drivers for the host system.
> I actually tested and found out that I get the same performance for
> usb using the ubuntu install on the host system and using the
> virtualbox guest additions.
> It would be nice that someone else could also verify these
> observations. In that case we could just install these packages before
> creating the VM, which would be much easier for our users.
I would also suggest to upgrade the OSGeo-Live Quickstart for Running in
a Virtual Machine, because a lot of little things are outdated: e.g.
the name of packages, screenshots of Virtual Box "Virtual Hard Disk"
and of VM settings "General- Advanced", but mainly: commands for
adding "VBOXADDITIONS".
Once more thank you!
Kind regards,
Elena
More information about the Live-demo mailing list
